intake fit questions after head work.
Old Mar 22, 2006 | 08:01 AM
Default intake fit questions after head work.
i am fixing to have my heads worked on, by getting a 5 angle valve job, mild porting and polishing, and shaving them about .030. my question is will i have any fitment issues with the intake after having the heads shaved. and what type of head gaskets and intake gasket should i look into. any help is appreciated.
Old Mar 22, 2006 | 08:37 AM
TurboGibbs's Avatar
flat surfacing of .030" won't effect intake fit at all. The stock mls head gaskets and stock intake gaskets work well. You can probably reuse your intake gaskets.
Richard@WCCH's Avatar
FormerVendor
We've milled over .045" without fitment issues. You should be fine milling .030".
Richard
Old Mar 22, 2006 | 08:53 AM
okay now knowing that, how much should i mill them. i will be racing quite a bit, and i will have flyer do the tuning to watch for knock after the raised compression. i am looking for the most out of it without sacrificing driveability and reliability. and is there anything else i should have done to them while i have him working on them.
Old Mar 22, 2006 | 08:59 AM
twobit's Avatar
I went close to .050 and didnt have any problems. I needed shorter pushrods.
Old Mar 22, 2006 | 10:52 AM
02sierraz71_5.3's Avatar
I took .050 off, you wont have any problems
Old Mar 22, 2006 | 11:09 AM
Originally Posted by twobit
I went close to .050 and didnt have any problems. I needed shorter pushrods. If you havent had your headwork done yet check with Chuck at Warrior. They are local to you.
Chuck Priestly
Warrior Performance Parts Inc.
(877) 206-0721 toll free
warriorperformance@yahoo.com
713 Northwest Drive
Wake Village, TX 75501
thanks, do you think i would have to have shorter pushrods by going only .030 or maybe .040?
Old Mar 22, 2006 | 11:12 AM
do you think it would be beneficial for my setup to go .050. or should i stay around .030 or .040. keep in mind im looking for the most power i can make without sacrificing realiability.
Old Mar 22, 2006 | 05:41 PM
Flyer's Avatar
Something else worth mentioning is the TR220 cam. You could go .030 on the heads and go with a thinner Cometic gasket, that way if there were a problem, you would be able to go back to a thicker gasket and be safe.
Old Mar 23, 2006 | 07:26 PM
Assuming you've got a 5.3 I could see going .060 with that 220 cam. I would check you p/v clearance after install, if you have issues you can always flycut they make tools for doing it with pistons still in the block. I think we can take alot of material off before issues with p/v as we have dished pistons, the ls1 guys run 12:1 routinely with flat tops and our 5.3 heads milled .050-stage 3 with huge valves
I dont see why we cant get away with a moderate cam like the tr220 and have compression in the same 12ish range. I really think cams like the tr220-224 and lpe gt2-5 love compression and no one has even touched the limits on this forum
So I say go .060 and show those boys in MS and LA whats up
