installed LT what a B****
Old Apr 14, 2006 | 09:29 AM
jm's customs's Avatar
Default installed LT what a B****
i installed my pacesetter LT last night what a pain in the *** that was. it wouldnt be that bad if i had some help and a lift but doing it yourself is a pain in the ***. first i undid the plug wires ripping two of them apart , then undid the y-pipe and the rest of the exhaust stripping one bolt attaching the y to the manifolds, and one attaching the y to the rest. ended up cutting the bolt the ataches the y to the rest of the exhaust. and tryed cutting the bolt attaching the y to the manifolds, after 2 blades i just cut the y pipe . took off the manifolds and found a broken bolt. tryed welding another bolt to the end, didnt work. tryed using vise grips after 20 min. and a whole turn later i gave up. went and found a socket that would hardly fit on the end hammered it on the bolt, put a socket wrench on it and was done in 20 sec. installed headers and gaskets tightened everything up, put in o2 sensors in and was done. all in all about 5 hours, damn im slow
couple of tips:
take out inner fender on p side it makes it easyer to get to bolts.
use a socket hammered on a broken bolt to take broken bolts out.
did everyone elses headers smoke at first. i guess just burning off all the ****
Old Apr 14, 2006 | 09:49 AM
LS1TRUCKGUY's Avatar
SOUNDS LIKE THOSE EXHAUST BOLTS KICKED YOUR ***! AT LEAST YOU GOT THE HEADERS ON AND DIDNT GIVE UP......MINE HAD SOME SH#T BURNING OFF OF THEM WHEN I FIRST STARTED IT UP.....
Old Apr 14, 2006 | 10:58 AM
TXsilverado's Avatar
did you have any pb blaster? that woulda helped with your bolt probs IMO. wd40 is not a substitute! i swear, i sprayed about a gallon of wd40 on my y pipe and couldnt get it loose. one litle squirt of penetrating oil and it came off like it wasnt even tightened down
Old Apr 14, 2006 | 11:20 AM
ThunderZ28's Avatar
12 Second Club
an easy out would have worked as well for the broken bolt
Old Apr 14, 2006 | 11:23 AM
whats an easy out?
Old Apr 14, 2006 | 11:25 AM
oh nm, i had to use one of those on my old silverado because the heater hose broke off inside of the motor because it was all corroded. i ended up using a chisel because the easyout didnt work for me.
Old Apr 14, 2006 | 12:18 PM
onebadrubi's Avatar
I can never get easy outs to work for me....they like to brake off also.
Old Apr 14, 2006 | 01:01 PM
91_bowtie's Avatar
Consider yourself lucky. I put my pacesetter's on last weekend and 2 bolts were broken off in the driver's side head. Thanks GM!
Old Apr 14, 2006 | 01:18 PM
thanks i dont feel so retarded now, so 5 hours is about average because of stupid stuff.
tx: your right wd40 sucks even though i went threw a whole big can.
01: iv never had any luck with easy outs, iv had a few brake. i like my socket idea but it only works if there is some bolt sticking out, i had about 3/4 inch
i had to drive it to school this morning about 5 min away damn what a loud SOB. but it was great there was some head turning going on. and my neighbors hate me.
Old Apr 14, 2006 | 01:46 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Your welcome for the advise at 4 in the morning
