Injectors Clogged. . . advice with options please.
Old Sep 20, 2014 | 02:00 PM
Jeebalow's Avatar
Default Injectors Clogged. . . advice with options please.
TL;DR Injectors clogged. Buy new set flow matched 38lb for $300 or have 8.1l truck injectors (31lb) cleaned for $200?
Long story:
I am wrapping up a drivetrain swap into my 95 ECSB. It's a 5.3 with 243 heads, 215/223 cam, NNBS intake, DBC TB for intake, LTs, 8.1L truck injectors, rebuilt t56, and 14B SF, trutrac, 4.88, Driveshaft specialties driveshaft.
I attempted to start the engine and only had one cylinder fire. I went through the typical spark, fuel, power to injectors check and have ruled it to be clogged injectors.
Should I send them off to be cleaned (about $200) or buy a set of new injectors ($300 for 38 lb deatschwerks). OR does anyone have a good way of cleaning them myself? I can soak them in cleaner, but is there a way to force the cleaner through?
Old Sep 20, 2014 | 02:01 PM
Jeebalow's Avatar
And because I am a pic *****:
Injectors in question:
Old Sep 20, 2014 | 02:11 PM
porksoda's Avatar
I've seen people jump the wires on it and pump through some cleaner that way *** opposed to just soaking them. I know the Carquest parts store in my town cleans and rebuilds injectors for a lot cheaper than $200.
Old Sep 20, 2014 | 04:00 PM
Jeebalow's Avatar
Thanks for the suggestion. Unfortunately, carquest by me doesn't clean injectors.
How do they pump the cleaner through when they jump them ? What is creating the pressure? Maybe I should draw something up and make it while I'm waiting for my driveshaft to be made. Could use shop air to pressurize it.
Old Sep 20, 2014 | 05:20 PM
Jason Z69's Avatar
Thats a good lookin set up. Nice install. Shop air should work. Just regulate properly. U can use a can with a hose in it to push the cleaner through the system.
Old Sep 20, 2014 | 07:44 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You need to pulse them and blow up through the injector to back flush.
If you have access to an ultrasonic device, and you can figure out how to pulse them, you could do it your self.
If your electro savvy you could make one. Here is a DIY for the pulser... https://www.youtube.com/watch?v=e5Dyr34qd_k
IF you search Youtube, there are some DIY tips and tricks for cleaning fuel injectors.
Old Sep 20, 2014 | 09:17 PM
Jeebalow's Avatar
Awesome, seems simple enough to make the 555 timer circuits. Thanks! I'll look into an Ultrasonic cleaner, put them in there and pulse them. The do the blow back to get more stuff out. I'm thinking of using clear pvc and turning some aluminum to fit each end of the injector and threading it into the pvc. I can pressurize one side of the injector at a time and and force the cleaner through in each direction while pulsing them. Should be under $50 when all is said and done. I'll update with any progress.
Old Sep 21, 2014 | 10:54 AM
porksoda's Avatar
You can use shop air or I've also seen people fill a big syringe with whatever cleaner they choose and attach it to the injector with hose and pressurize it by just squeezing down on the syringe.
Old Sep 21, 2014 | 10:56 AM
Jason Z69's Avatar
1 FastBrick. Thanks for the link. U always seem to have some good info.
Jeebalow. Good luck with the cleaning.
Old Sep 22, 2014 | 05:44 PM
Jeebalow's Avatar
I went to Harbor Freight and bought an ultrasonic cleaner for $35. Put the injectors in there with fuel system cleaner and cleaned for about 10 min. Then powered them up to make sure solenoid was free. This is the result
5.3 in 95 C1500 First Start - YouTube
ARC
57
Feb 21, 2022 10:54 AM
gaps
Sep 2, 2015 01:19 PM
chevy6.0fan
Aug 20, 2015 07:10 PM
RONIN LSX
Aug 11, 2015 12:03 AM
