Finally acquiring parts for a 402lsx build
Thanks to Andysc3, I finally have a viable block to start my build. The bores checked out and while it may end up being a honed 404, I figured 2ci wouldn't make much of a difference. Please take a look at the list and tell me if there's anything in there that might not belong or work very well with the other components. Back-story, 4.8 is dead as the block is cracked, so I figured might as well take the time to upgrade. Already have a built 4l80e on the way with a circle-d 3800 stall. My intention is to make the engine as bulletproof as possible. What is not listed are the L92 heads I'm currently having ported, the fuel pump which I haven't ordered yet, the headers which I'm still trying to decide between 1 7/8 or 2in primaries, or any of the gaskets. My intention is to have a bulletproof engine rev'ing to a max of 6800 while still providing decent street manners. For the rear gears, I'm thinking along the lines of 3.73's as I would like to be in the 2200rpm range at cruising speed (75mph). Thanks for any advice you offer gents. Last thing, at some point in its life, this engine may see boost at which point I'll have a cam spec'd to match.
Comp Cams LSr-Series Hydraulic Roller Camshaft-243 / 251 .624/.624 114 LSA
Comp Cams "Comp R" Hydraulic Roller Lifters
Precision Race Components .675" EHT Double Spring Kit
Comp Cams Retro-Fit Rocker Arm Trunion Kit; All GM LS Engines
Comp Cams, Gen III Billet, Double Roller Timing Set w/ Captive Torrington and 9 Keyway Crankshaft Sprocket-LS1/LS6, early LS2 (w/ 24x Reluctor)
TSP 402 C.I.D. LQ9/LS2/L98/LY6 Rotating Assembly
- TSP Forged Crankshaft
- Callies Compstar 6.125" H-Beam
- Wiseco 4.010" -2cc Flat-Top (10-AW-01924)
- Please Include Clevite Main & Rod Bearing Sets
- Balance Rotating Assy.
- 24x
Texas Speed Ported LS6 Oil Pump w/ O-Ring
F.A.S.T. 65 lb. Fuel Injectors, For L76, L92, LS7
F.A.S.T. Big Mouth 102mm Throttle Body With TPS Sensor
FAST LSXR 102mm LS3 Intake Manifold
Texas Speed 100mm Mass Air Flow Sensor
- 24x
