injector question
Old Nov 7, 2010 | 09:23 PM
stick1975's Avatar
My truck is an 01. So stock injectors should be fine for my mild build then? That would be real nice.
Old Nov 7, 2010 | 10:44 PM
budhayes3's Avatar
PT's Slowest Truck
Yep, your 4.8 and 6.0 injectors are the same, you'll be fine until you start going with a bigger cam or headwork, etc.
Old Nov 7, 2010 | 10:55 PM
Mangled03gmc's Avatar
Baltimore Whore
Like Billy said, 4.8-6.0 injectors are the same... The pcm needs to be reflashed, fuel, timing trims-tables change...
Old Nov 7, 2010 | 11:20 PM
mhotrodscooter's Avatar
Just asking.. Why we I ran the 4.8 injectors it would throw a lean code & after I put the 6.0 injectors it wouldn't? Doesnt different numbers mean different parts?
Old Nov 8, 2010 | 07:44 AM
fredkj3's Avatar
I ran for about a year with a 6.0 on 4.8 injectors, no problem. like they said, they are the same flow rate. you should be fine. Now when you put a cam in you will begin maxing these injectors out.
Old Nov 8, 2010 | 10:39 AM
Now this was running the 4.8 PCM with no tune..
Old Nov 8, 2010 | 11:26 AM
budhayes3's Avatar
PT's Slowest Truck
I think that's why you got the lean codes, different cubes and VE...
Old Nov 8, 2010 | 11:32 AM
Thanks Billy, so their must be a little something different in the injectors..
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
blackdc3
Jul 7, 2015 07:52 PM
