If this doesn't fix it I give up
Old Oct 5, 2009 | 06:07 PM
  #71
GMCtrk's Avatar
Nothing changed as far as the KR goes.
I changed
1)intake gaskets
2)new intake manifold/new rails, injectos, tb, etc - whistling air leak sound gone
3)new knock sensors/harness
4)ordered catch can today
I really do need to get a wideband on this thing, but I don't believe it's going lean causing the knock...reason being the o2 sensors stay constant from no knock to when it supposedly knocks
Old Oct 5, 2009 | 06:22 PM
  #72
BlackGMC's Avatar
Resident Retard
you got a log and tune you can post?
Old Oct 5, 2009 | 06:39 PM
  #73
GMCtrk's Avatar
Sure Corey
File Type: efi
File Type: efi
File Type: efi
Old Oct 5, 2009 | 07:12 PM
  #74
hirdlej's Avatar
Did you have the severe oil consumption before installing the TSP heads?
Old Oct 5, 2009 | 07:15 PM
  #75
GMCtrk's Avatar
My motor doesn't burn any oil. I wasn't even aware of oil being sucked into the intake until I pulled it off.
Old Oct 5, 2009 | 07:19 PM
  #76
hirdlej's Avatar
Ok, let me re-iterate myself then. Did you have your intake manifold dripping so severely of oil before installing the texas speed cylinder heads?
Old Oct 5, 2009 | 07:21 PM
  #77
GMCtrk's Avatar
Yes. It was like that with the 4.8. And I was being dramatic. There were 1 or 2 drops of oil from the intake manifold. It is more or less a light mist of oil covering all the intake ports. From what I understand this is common on LS engines. I even saw a picture of a LS7 intake manifold that had oil pooled in the bottom
Old Oct 5, 2009 | 07:28 PM
  #78
hirdlej's Avatar
Well, FYI I just swapped intake manifold gaskets and an oil pressure sending unit on a coworkers '00 LS1 vette. It actually poured out and left a puddle on his garage floor when I set his intake on end. I was like WTF. I reassemled everything and it's fine but still, I've seen it anyways.
Old Oct 5, 2009 | 07:29 PM
  #79
nonnieselman's Avatar
Remove your PCV and put breathers on your valve covers.. I did that on mine so i would stop blowing oil out of the passenger side valve cover that i had a small filter on when i got in boost..
this way no oil is goin in your intake
Old Oct 5, 2009 | 07:30 PM
  #80
GMCtrk's Avatar
Yep, I think my truck has the really bad PCV system on it too. I'll be interested to see how much oil the can catches.
