If this doesn't fix it I give up
Old Oct 4, 2009 | 09:44 PM
  #61
budhayes3's Avatar
PT's Slowest Truck
Don't give up Michael, we'll figure it out. Definitely get a catch can that has a petcock on the bottom, you don't want to have to remove it to dump it every time it fills up, which is quite often. I get at least a tablespoon of oil out of mine every 500 miles.
Old Oct 4, 2009 | 09:48 PM
  #62
GMCtrk's Avatar
It looks like it has the valve on the bottom
Old Oct 4, 2009 | 09:49 PM
  #63
budhayes3's Avatar
PT's Slowest Truck
Yea, that looks nice. I just get a dixie cup or brakleen can cap and drain into that...I wonder what the filter's for
Old Oct 4, 2009 | 10:02 PM
  #64
hirdlej's Avatar
I disabled the Knock Sensors on my truck and haven't had issues. If it knocks, just take your foot out of it. I've never blown a motor up to detonation in my life and drive **** hard.
As far as the catch can goes, have Saikou Michi make you one. I had him build me a custom one for my ride. It's nicer than the rev xtreme:
Old Oct 4, 2009 | 10:08 PM
  #65
GMCtrk's Avatar
That catch can is too small. I want at least a 1 qt. one. The Rev one matches my budget and needs.
Also, it's certainly plausible that the oil is causing detonation. The only thing is I HEAR NO KNOCK! One second my screen shows 0 KR the next moment it's up to 7 KR and I hear no change in engine sound or anything???
Old Oct 4, 2009 | 11:33 PM
  #66
budhayes3's Avatar
PT's Slowest Truck
Run the race gas man and see what happens...as far as real knock goes, I've seen pistons with huge holes in them from real detonation. My father recommends that his customers run knock sensors on their race engines, wired to a warning light in the cockpit so the driver can get out of the throttle before Chernoble(sp?) happens in his engine...
Old Oct 5, 2009 | 01:06 PM
  #67
hirdlej's Avatar
LMAO, if you need a 1 quart catch can you have more serious problems at hand.........
Old Oct 5, 2009 | 01:08 PM
  #68
dlt76028's Avatar
imho spending a 100 bucks on a catch can is not going to fix 8 degrees of knock...
Old Oct 5, 2009 | 05:50 PM
  #69
GMCtrk's Avatar
What do you suggest I do then? I can't seem to get this motor running correctly.
Old Oct 5, 2009 | 06:00 PM
  #70
BlackGMC's Avatar
Resident Retard
hey, so what all have you replaced? Make a list and post it... That might be a better way of helping you determine what is wrong... Maybe a list and what each part did ... For example what happened after you replaced the intake gaskets??
