If this doesn't fix it I give up
Old Oct 3, 2009 | 01:42 PM
GMCtrk's Avatar
Default If this doesn't fix it I give up
What do you all think? This is the root of my false knock at WOT?
New sensors in, torqued to 15 ft.lb and sealed off with high temp, sensor safe rtv
Old Oct 3, 2009 | 01:49 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Could definately have been contributing to your troubles.
Old Oct 3, 2009 | 01:54 PM
GMCtrk's Avatar
Oh, and I also should add, I have a massive oil suction into my intake. There is literally oil dripping from the intake gaskets and on the intake ports of the heads. I just had the intake off a couple weeks ago and cleaned all the oil off.
Old Oct 3, 2009 | 02:14 PM
Mangled03gmc's Avatar
Baltimore Whore
Do away with the pcv..
Old Oct 3, 2009 | 02:16 PM
GMCtrk's Avatar
Just put a breather on that hole? Or get a catch can?
Old Oct 3, 2009 | 02:18 PM
Tootall's Avatar
time for a catch can . . .
Old Oct 3, 2009 | 02:21 PM
fastnblu's Avatar
Why, John?
OP, is it normal for knock sensors to get all nasty like that or does it have to do w/. climate, like say where a lot of road salt is used?
Old Oct 3, 2009 | 02:31 PM
00Silv4.8's Avatar
its not necessarily the outside of the sensors that will cause a false knock. Those sensors have crystals inside of them that vibrate or pick up the certain pitch of a 'knock' IIRC. So its kind of a hit or miss thing.
how many miles does your motor have that your DRIPPING oil out of the intake? I just pulled my 6.0 and its relatively clean for ~4k miles
Old Oct 3, 2009 | 02:33 PM
dlt76028's Avatar
i think it will help. dont give up..
Old Oct 3, 2009 | 02:36 PM
GMCtrk's Avatar
If this isn't it, then it has to be something mechanical. If this doesn't fix it I may try running some race gas when I'm almost out of gas and see what that does. It it's still getting the same knock then, then there's some other cause of the false knock.
