IAT's went down. Ha! Ha!
Old Jun 11, 2005 | 08:15 AM
Default IAT's went down. Ha! Ha!
Well I took out the decorative Stainless Steel radiator Grill off and my IAT 's dropped at least 25 degrees. ECT's were down 20 and typically stayed in the 170's after 35mph. Most of the Low throttle KR went away. The radiator grill I had was a stamped 304 stainless steel with small holes punched out. I will look for a billet grill which seems much less restrictive. so basically before the by pass valve engages the supercharger the IAT's were 30 degrees above ambient max. Before removing grill, It was at 55-60 above ambient. Once the systems sees boost, the IAT's still get pretty high but now peaks out 10 degrees less than before. The engine feels a lot stronger. So I have ordered my chemical intercooler for now to take care of the boosted air temps!
So the lesson I learned is Dont buy the Stainless Steel Grill unless it has big holes in it to allow proper airflow.
Old Jun 11, 2005 | 09:33 AM
ronn25's Avatar
I've often thought about aftermarket grilles being more restrictive. I have saw many that looked restrictive. Good info.
Old Jun 11, 2005 | 10:49 AM
Crash Dummy's Avatar
Former Moderator :(
Airflow = Lower temps, Go figure!
Old Jun 11, 2005 | 11:26 AM
therock's Avatar
Default What About Insulating ....
....the intake tube from under hood heat?
Has this ever been tried.
Old Jun 11, 2005 | 04:13 PM
The way my Supercharger is set up, that would probably get a couple of degrees lower before the bypass valve kicks in.
Old Jun 11, 2005 | 07:01 PM
03sierraslt's Avatar
Hey V. I have been trying to get ahold of you, give me a call if you see this post.
GMCtrk
Jan 27, 2016 06:47 PM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
JordanH
Oct 3, 2015 03:59 PM
MOBBN
Sep 22, 2015 08:07 PM
TAPyvehc93
Sep 17, 2015 10:10 AM
