I need help with maxed out LTFTs
Old Jan 28, 2014 | 11:15 AM
cueball's Avatar
Default I need help with maxed out LTFTs
My brother-n-law has a 2004 Tahoe with the 5.3 flex fuel engine.
His LTFTs are maxed at 25%.
I did the simple things first, I cleaned the MAF, and checked fuel pressure and found it idles at 40 psi, 38 psi revving, and 50 psi with the vacuum line pulled off of the fuel pressure regulator.
With the fuel gauge still hooked up, I clamped the return line and the pressure jumps to 80 psi.
I pulled the regulator off and inspected it, I found that it is bypassing so we replaced it with a new regulator.
Before I installed the new one, I checked it for bypassing and it does not, its perfectly fine.
I installed the new regulator, and still low pressure, 40, 38, and 50.
And when I clamp the return line, it jumps to 80, and when we shut off the engine, the pressure holds at 40 psi. It does not bleed off.
Is the fuel pump bad?
Iv'e read several post and they seem to say it should be between 58 psi and 62 psi, but most also say that they don't get a change when they clamp off the return line.
We do, it jumps to 80 psi.
Any help will be appreciated.
Thank you.
Old Jan 28, 2014 | 11:40 AM
cueball's Avatar
Forgot to mention, we replaced the fuel filter too.
Also, I didn't have any starter fluid on me to check the intake and gaskets for leaks.
I guess my next thing to do is to get some starter fluid and check for vacuum leaks.
Old Jan 28, 2014 | 11:59 AM
Atomic's Avatar
I have a gauge for that
Sounds like it could be the pump. Regulators do not break that often.
Old Feb 4, 2014 | 02:04 PM
cueball's Avatar
Update...
Ok, I fixed the problem.
It was the intake gaskets.
I decided to do a test drive with the scanner, I saw that the LTFTs would go normal under acceleration or a load.
I figured then, that it was a vacuum leak.
When I got back, I left the engine running and sprayed starter fluid around the intake, instantly the LTFTs went negative.
I replaced the intake gaskets and everything is running fine now.
LTFTs are around zero again.
Old Feb 4, 2014 | 02:12 PM
Atomic's Avatar
Intake leaks are usually coupled with a high idle speed. Was it ideling high?
Old Feb 8, 2014 | 11:58 AM
cueball's Avatar
No, it was idling around 600.
I did notice the MAP was at 35 Kpa instead of 33 - 34.
And the throttle was closed at 1%
Old Feb 8, 2014 | 12:40 PM
03sierraslt's Avatar
Your fuel pressure still isn't right, and 1 kpa different in map reading doesn't mean ****. Under a load fuel trims are supposed to go 0 as that is open loop.
Old Feb 20, 2014 | 02:20 PM
Yep I agree, fuel pressure isn't right. Low pressure causes maxed trims, I've seen it personally on multiple occasions. Motor can otherwise drive fairly normally it will just be down on power but even that may not be extremely obvious.
gaps
Oct 15, 2015 02:53 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
2plus2
Sep 13, 2015 07:17 PM
JordanH
Sep 12, 2015 12:02 AM
creekrat
Sep 10, 2015 12:59 AM
