5.3 turbo help
Old Feb 18, 2014 | 08:42 AM
loganauld's Avatar
Registered User
Default 5.3 turbo help
Ok so im 5.3 turbo swapping a 98 obs ext cab but ive never turboed anything before so im just looking for some advice before i jump into it. Like what are good cam specs, heads, intake, fuel, exhaust set up, what works what doesnt, dos and donts ect.. any advice would be GREATLY appreciated thanks
Old Feb 18, 2014 | 10:17 AM
Blackpanther99's Avatar
What are your HP goals? Daily driver?
Old Feb 18, 2014 | 10:19 AM
Atomic's Avatar
I have a gauge for that
Before you spend a dime spend about 200 hours reading on this forum and others about guys installing turbos. It is way more involved than you would think.
Old Feb 18, 2014 | 11:29 AM
Turbo09's Avatar
+1 for ^
I was in a similar boat as you, I had the truck but no turbo experience.
I read up on here on turbos, kits, $, and so on.
If you have an actual question just PM people who have done it. but first read their build threads.
After all of that go back to your bank and look for the money lol
Good luck
Old Feb 19, 2014 | 09:53 AM
loganauld's Avatar
Registered User
500-600 and somewhat daily, i have another vehicle for milage but i wanna be able to cruise in the truck while its bice outside
Old Feb 19, 2014 | 09:56 AM
loganauld's Avatar
Registered User
Originally Posted by Turbo09
+1 for ^
Good luck
Yeah ive been researching like crazy lol thats why i posted this, to get some kind of idea what all im gonna need
Old Feb 19, 2014 | 12:36 PM
Read build threads. Learn about turbo setups. 500-600 hp isn't tough to accomplish, but you gotta learn a lot before pulling triggers.
Most likely you will be buying a turbo kit no? Call Trick Performance or On3 performance for a complete turbo kit.
From there you gotta look into your drivetrain.
Old Feb 19, 2014 | 10:28 PM
loganauld's Avatar
Registered User
Got a nine inch and plan on 4l80e but what about fuel system, do i need a new fuel pump? injector size?
Old Feb 20, 2014 | 02:44 PM
Turbo09's Avatar
Go fo 60Lb injectors at least, find a Injector calculator and use it. Yes you need a bigger fuel pump A flex fuel pump may supply that much but better to do your research. also a built 4l60 will handle that fine.
Choda
Jan 22, 2026 02:03 PM
Jake99
Aug 8, 2015 07:56 AM
05GMC4.8
Aug 7, 2015 09:55 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
71ls2
Jul 20, 2015 11:53 PM
