How tough is it to do a cam change?
Old Jul 27, 2005 | 12:41 AM
natesiy's Avatar
Default How tough is it to do a cam change?
What has to come out? I heard the rad, fan, belts, grille. Anything else? How tough is it to do yourself?
Old Jul 27, 2005 | 03:18 AM
CAMMIN03''s Avatar
Banned
Well I dont know if its the actually swap part thats hard.... You just have to keep the lifters up...
The hard part is having all the tools to take the other **** off..
and the knowledge of putting it back together...
Old Jul 27, 2005 | 03:53 AM
black4x4's Avatar
for mine i took the fan shroud radiator water pump front cover cam gear rocker covers rocker arms spring push rods and starter and front pully its not to hard to do.
Old Jul 27, 2005 | 07:27 AM
white1's Avatar
I didn't pull my grille. The cam swap I found was easy. The springs were a PITA though. At least till I got a good spring compressor. I'm ready to do it again
Old Jul 27, 2005 | 11:52 AM
Okie5.3's Avatar
not necessarily hard, but time consuming. like white1 said, the springs are a pain. the damn oil pan to timing cover bolts (2) were a pain for me to get started when putting it back together.
Old Jul 27, 2005 | 12:11 PM
O3GMC's Avatar
12 Second Club
http://ls1howto.com/index.php?article=23
Old Jul 27, 2005 | 12:12 PM
white1's Avatar
The cam swap was easy IMO except for thosw two bolts. I have LS1 fans though. I'm thinking of putting my stock cam back in and selling mine so I can go bigger . Its not hard once those springs are done. I had a hard time getting the pully back on, but I think I figured out a trick for that.
Old Jul 27, 2005 | 12:42 PM
KLUG'S SS's Avatar
FormerVendor
If you don't mind me asking what kind of trick did you figure out for putting the pulley back on because I had one hell of a time getting mine back on. Might be doing another cam swap soon and I am dreading getting that damn pulley back on again.
Old Jul 27, 2005 | 01:05 PM
white1's Avatar
Its probably not a good idea, if you do it, put some grease on the outside. I took a butane torch and heated up the INSIDE of the pulley, and put it on by hand except for about the last 1/4-1/2"
Old Jul 27, 2005 | 04:16 PM
O3GMC's Avatar
12 Second Club
I've read just to heat the pulley up in the oven for about 10 min, "slides right on"
ARC
57
Feb 21, 2022 10:54 AM
07NBSChevy
Aug 9, 2015 12:59 AM
Jake75
Aug 5, 2015 01:26 PM
steves86ta
Jul 28, 2015 10:21 AM
Suburban2500
Jul 19, 2015 04:50 PM
