How often do you guys change fuel filter?
Old Sep 6, 2005 | 07:43 PM
  #31
Post
Actual recommended fuel filter replacement is every 15,000 mi.
Jim
Old Sep 6, 2005 | 07:45 PM
  #32
Mr. Sandog's Avatar
Jim
Hmm. Then howcome the dealer didn't recommend or (even acknowledge this recommended interval) when I brought the vehicle in for servicing over the last 2 years?
Old Sep 7, 2005 | 02:50 AM
  #33
Wilde Racing's Avatar
How do I change this text
Originally Posted by SierraCrew
Drop the fuel tank
I think it is easier to pull the bed.
Old Sep 7, 2005 | 10:14 AM
  #34
04Denali's Avatar
When I put my Radix in my mechanic pulled the bed. said it was easier since I had 1/2 a tank of gas
Mark
Old Sep 7, 2005 | 05:25 PM
  #35
Post
Hmmmm, are all dealership's service departments the brightest or most knowledgeable?????
It's recommended every 15,000 mi.
Jim
Old Sep 8, 2005 | 09:35 PM
  #36
DrX's Avatar
DrX
On the 04's you can replace just the filter, I did mine when I changed the fuel pump. You have to drop the tank and remove the fuel pump module. Be carefull when pulling the module apart as to not break off the plastic tabs. If you would like to see how it is done Magnacharger has good pics and instructions on there web site.
Where did you buy the filter? The only part that GM sells separately from the whole module is the fuel level sensor.
Here are some pics from the Magnacharger instructions for my vehicle. I added the arrows indicating the filter. The instructions are only for replacing the pump. Haven't seen anything wrt the filter.
Attached Thumbnails How often do you guys change fuel filter?-picture-001.jpg   How often do you guys change fuel filter?-picture-002.jpg
Old Sep 14, 2005 | 02:16 PM
  #37
slowprocess's Avatar
Just changed my filter. Completely stopped up, which can never be a good thing.
Old Sep 14, 2005 | 02:27 PM
  #38
BLACKHD01's Avatar
Changed mine last night, could barely blow through it , and you could see plenty of trash in it. Truck has 60,000 miles on it.
Old Sep 15, 2005 | 04:33 PM
  #39
ngianop's Avatar
Originally Posted by KLUG'S SS
Thanks to everybody for the responses about this, like I said before found it a little odd for my filter to be in the shape it was in for the mileage that was on it.
I better stop letting my tank get down to the last gallon or so before I fill back up.
I change my truck's filter every year.
You might also consider buying gas from another station and see if that makes a difference. Maybe the tank at your normal station is dirty. (or their supplier is delivering contaminated fuel)
I was riding in a friends diesel through Canada once. Truck ran great for most of the trip then suddenly it acted like a four-banger. Turns out the fuel from the last place we stopped was contaminated with water. (supply tank must've been low...)
Sorry to hear that the fuel filters on the newer trucks are buried in the tank. Makes me glad I have an '02.
Old Sep 15, 2005 | 06:13 PM
  #40
Mort's Avatar
Cool
My '03 Owner Manual recommends changing the fuel filter every 30000 miles.
