How often do you guys change fuel filter?
#23
If you've been running ethanol blended gasoline(gasohol), it's most likely your filter is gonna plug sooner for a little while. Gasohol is very clean, and it pretty much washes the varnish out of your tank. In Saskatchewan by 2006, I think all gasoline will be blended with a little ethanol. The plus side is that it will be a higher octane for the same price as regular.
#26
FormerVendor
Originally Posted by black4x4
when you change the filter does gas run out all over or is it cut off cause the pump isent running?
#28
Originally Posted by OCBC
So, whats involved in changing the filters for the 04's then?
#29
On the 04's you can replace just the filter, I did mine when I changed the fuel pump. You have to drop the tank and remove the fuel pump module. Be carefull when pulling the module apart as to not break off the plastic tabs. If you would like to see how it is done Magnacharger has good pics and instructions on there web site.
