how much PSI in tires when racing?
Old Nov 9, 2003 | 09:07 PM
hyper's Avatar
Default how much PSI in tires when racing?
for a street race how much psi should i have in my tires for good traction. they are 18s with 255/55/18
Old Nov 9, 2003 | 10:49 PM
hyper's Avatar
coomoon anyone know?
Old Nov 9, 2003 | 11:06 PM
Keith's Avatar
Since you have positraction, you need to do a couple of tests to find your best psi. Do a burnout on clean concrete, check to where the rubber is: either on the center or outside ot the tire width. Then adjust your pressure to get an even mark across the width of the tire. I am pretty sure this is the way to do it with radials.
Old Nov 9, 2003 | 11:21 PM
With a street tire and leaf springs,run as much pressure as you can without wheelhop.Start with about 26psi and either add or drop your tire pressure after a test run.Find a vacant strip of asphalt,take an air tank and a good air guage,then keep notes that include outside temp and air pressure.
Old Nov 10, 2003 | 12:03 AM
FILE's Avatar
I have gotten good results with 22psi.
Old Nov 11, 2003 | 10:36 PM
Quik's Avatar
5 year bitches!
i run with normal air pressure in my 235/75/16s around like 33
Old Nov 12, 2003 | 12:32 AM
GoldenVelvet's Avatar
I run normal air pressure with my 285/60/17 but 285 is kinda wide.
GXPJAY
Feb 13, 2022 08:15 AM
Go5.3tt06
Sep 12, 2015 09:29 AM
Gadgetized
Sep 9, 2015 10:46 PM
Ls3silverado
Jul 31, 2015 04:22 PM
jrplz
Jul 9, 2015 12:07 AM
