how much PSI in tires when racing?
Since you have positraction, you need to do a couple of tests to find your best psi. Do a burnout on clean concrete, check to where the rubber is: either on the center or outside ot the tire width. Then adjust your pressure to get an even mark across the width of the tire. I am pretty sure this is the way to do it with radials.
With a street tire and leaf springs,run as much pressure as you can without wheelhop.Start with about 26psi and either add or drop your tire pressure after a test run.Find a vacant strip of asphalt,take an air tank and a good air guage,then keep notes that include outside temp and air pressure.
GXPJAY
Feb 13, 2022 08:15 AM
