How much hp can a stock 4L80e can hold??
Old Nov 13, 2013 | 10:22 PM
Lootbeans's Avatar
Registered User
^true the overdrive is stronger an the oil cooler stub outs on the right side are spaced out to front an rear for better cooling instead of together my 02 2500 gmc 6.0 held 450 to the wheels with cam an a single wet shot!
Old Nov 13, 2013 | 10:25 PM
gamble686's Avatar
If you can get a low mileage unit with a shift kit and a big trans cooler then you should be good unless you beat on it all the time. Basically any built 80e from a reputable builder should get it done.
Old Nov 14, 2013 | 09:52 AM
Vortec350ss's Avatar
At that power level I would upgrade to the level 4. The billet fwd clutch hub alone cost as much as that price difference... I think its worth it.
Old Nov 14, 2013 | 10:08 AM
Cammed4ever's Avatar
4L60E to 4L80E Swap, Attention 4WD Owners with Superchargers
What do you think about that output shaft?? Is that any good??
I was told by a local mechanic that that was the way to go..
Old Nov 14, 2013 | 10:28 AM
03sierraslt's Avatar
No, that output is made to be the same size as a 60e output shaft which makes it the weak link. Change the tcase input instead.
Oobray
Jun 13, 2022 03:38 AM
XL7
May 5, 2022 01:48 PM
Alco
Jul 25, 2015 01:47 PM
76k10chase
Jul 17, 2015 01:48 PM
zaathur151
Jul 6, 2015 10:57 PM
