how to make truck run 13s?????
Old Jul 7, 2003 | 07:01 PM
ineedatruck's Avatar
Default how to make truck run 13s?????
I have a single cab with the 4.8. i want to out run lightnings all motor or come close. Wut should i buy and wut numbers and price will it be. i have 2grand for performance. id prefer not to spray
Old Jul 7, 2003 | 07:23 PM
Default Re: how to make truck run 13s?????
Radix Magnacharger,ASM headers,Yank 3000,4.10 gears and a Eaton posi.About $7500.
Old Jul 7, 2003 | 07:29 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I don't know how you would outrun an L on just motor. The L's are supercharged, so good luck.
If you want to come close, umm...I dunno where to start...
1)cam+tuning (~$700)
2)Intake ($200)
3)exhaust ($1000)
The essence of horsepower is getting air and fuel in and out of an engine as fast as possible.(right guys?)
Intake and exhaust helps, and a bigger cam lets more fuel+air in.
I also have a 4.8 and would like to wake it up a bit, that's probably what I will do.
Old Jul 7, 2003 | 07:32 PM
L has 380 hp.....if i buy superchip tuner, asp pulley, aem intake, headers, muffler, cam, port and polish........i can get port and polish free.....but would that put me over 2 grand wut wut should i run cam wise and if i do a cam i need wut else?????
He's only got 2Gs man.
That reminds me, I got an Eaton posi and 4.10 gears for $800 installed. While that doesn't add power, it got the power I have to the ground. Before I was doing the infamous "one wheel peel" and wouldn't go anywhere. Now, the Eaton hooks up, the 4.10s haul better, and I'm outta there. Not to mention the fun you can have with the Eaton when going around corners.
Old Jul 7, 2003 | 07:35 PM
I was looking at either a Crane cam...or a Comp cam. It depends on where you want the power. Alot of guys say when you add a cam you lose some low end, but a Yank 3000 will take care of that problem. A cam will need tuning to get the most out of it
Old Jul 7, 2003 | 07:42 PM
i will be isntalling everything....so how much will ea. piece cost and how much is it
He can't do it for $2000 unless he sprays the devil out of it.With ASM headers,Yank 3000,4.10s a Eaton posi and a 150 shot he might make it for $2000.
Old Jul 7, 2003 | 07:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
13's aint gunna happen on 2 g's
Old Jul 7, 2003 | 07:44 PM
Unfortunately, you are correct
