How important are boost and air to fuel guages?
Old Aug 29, 2005 | 06:19 AM
  #31
wkdivr's Avatar
[QUOTE=DrX]Let me know when you get some dyno numbers on your setup. Mine were 319Rwhp/349Rwtq. Still think something isn't quite right though. Just noticed that my fuel pressure gradually drops from 60 to 56 during a WOT run.
I think that drop is acceptable. It should blip slightly on shifts, too.
Old Aug 29, 2005 | 08:35 AM
  #32
DrX's Avatar
DrX
Originally Posted by therock
Did your Radix kit come with the 8.1 fuel pump or the in-line booster?
The in-tank pump. See here also: https://www.performancetrucks.net/fo...78#post3167278
Old Aug 29, 2005 | 08:47 AM
  #33
Wilde Racing's Avatar
How do I change this text
DrX, have you hooked up the wide band so you can log with it?
Old Aug 29, 2005 | 10:27 AM
  #34
DrX's Avatar
DrX
Yes I have. Also ordered EFILive.
Idles around 15 AFR. Steady at 14.8 while cruising. Enriches under boost. Was holding at 11.8 at WOT initially and when I dynoed it(could smell the cats when I backed off the throttle) but last time I looked at it under WOT I think it only went down to around 12.2.
Edit: I take that back. Held at 11.75 at WOT today. Maybe the 12.2 I saw before was an anomoly.
AT WOT boost kicks in at 6 psi and gradually climbs to just over 7.5 by the time I back off at around 85mph(not sure what the tach said).
Old Aug 29, 2005 | 09:31 PM
  #35
JimS's Avatar
Does the pillar with the guage pods have the grained like leather look that the stock pillars have or is it smooth plastic?
Old Aug 29, 2005 | 09:44 PM
  #36
DrX's Avatar
DrX
Grained. Mine is a good match.
Old Aug 29, 2005 | 09:51 PM
  #37
JimS's Avatar
What brand or where did you buy yours?
Old Aug 29, 2005 | 10:15 PM
  #38
DrX's Avatar
DrX
AutoMeter.
Old Aug 30, 2005 | 10:08 AM
  #39
Hey DrX, where did you tap in for you RPM pick-up? And are you using the analog for any sensors? thanks
Old Aug 30, 2005 | 01:55 PM
  #40
DrX's Avatar
DrX
Used an injector wire for RPM. Hooked up TP and boost sensors, Haven't calibrated them yet though.
