How important are boost and air to fuel guages?
#31
[QUOTE=DrX]Let me know when you get some dyno numbers on your setup. Mine were 319Rwhp/349Rwtq. Still think something isn't quite right though. Just noticed that my fuel pressure gradually drops from 60 to 56 during a WOT run.
I think that drop is acceptable. It should blip slightly on shifts, too.
#32
Originally Posted by therock
Did your Radix kit come with the 8.1 fuel pump or the in-line booster?
#34
Originally Posted by Wilde Racing
DrX, have you hooked up the wide band so you can log with it?
Idles around 15 AFR. Steady at 14.8 while cruising. Enriches under boost. Was holding at 11.8 at WOT initially and when I dynoed it(could smell the cats when I backed off the throttle) but last time I looked at it under WOT I think it only went down to around 12.2.
Edit: I take that back. Held at 11.75 at WOT today. Maybe the 12.2 I saw before was an anomoly.
AT WOT boost kicks in at 6 psi and gradually climbs to just over 7.5 by the time I back off at around 85mph(not sure what the tach said).
#40
Hey DrX, where did you tap in for you RPM pick-up? And are you using the analog for any sensors? thanks
