How to determine 6.0's
Old Jul 15, 2007 | 02:31 AM
  #21
gmforlife's Avatar
Originally Posted by sliderbkt
True. If you think you will do nothing to the motor after you buy it, then hold out for the LQ9.
But, If you think you will build it up, then just make sure you get a 6.0l block with the good heads. I don't think you have an FLT 80e for 345hp though.
Buy it-Break it-Build it!
Yah i know the transmission will over power pretty much any stock motor, but the tranny might not stay in this truck, i would like to put it in a rcsb or maybe trade back FLT or sell it to get an FLT t56. We will see, gotta get the motor first, i'll hear from my buddy tomorrow, he said $500 for an SS 6.0, but then again that's just talk. I'm crossing my fingers cause if that's true i'll write a check tomorrow.
Old Jul 15, 2007 | 04:25 AM
  #22
usabodyguard's Avatar
Blown 427 LSX
other than dished pistons, isnt the lq4 the same as the lq9?... get the cheaper lq4 and throw some diamond pistons in it... of course i could be wrong...
what the hell do i know...
Old Jul 15, 2007 | 06:25 AM
  #23
ap2002's Avatar
if you get the LQ4 just mill the heads to get you the LQ9 compression...
by the way there is nothing wrong with modding an extended cab!!
Old Jul 15, 2007 | 09:53 AM
  #24
Mort's Avatar
The LQ9 has stronger rods as well as flat top pistons AFAIK.
Old Jul 15, 2007 | 10:01 AM
  #25
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Denalis and C3s also had LQ9s, not LQ4s. AFAIK, SSS, Denalis, C3, Esky, and VHOs where the LQ9 equipped trucks. HDs and CCs where the LQ4s.
The only difference is rods and pistons and you'll be replacing both if you do a 408. Because of that, paying the extra coin for a LQ9 seems a bit silly. The LQ4 is 9.4:1 and the LQ9 is 10.1:1. If your buddy can get a 6.0 for $500, DO IT and worry about the pistons at rebuild time
Old Jul 15, 2007 | 11:27 AM
  #26
ZZebes's Avatar
ain't that the truth
Old Jul 15, 2007 | 11:49 AM
  #27
1Bear's Avatar
C3's and Denali's unfortunately came with LQ4's. Sierra Denali's starting in '05 got the LQ9 (when they became crew cabs). While it is true that the only difference is the rods and pistons, also starting in '05 all the 6.0L's including the LS2 got the same floating pin rods.
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
