How to determine 6.0's
Originally Posted by TarheelZ
Oh, yeah...now you're talking! I would LOVE to have a t56 behind the 6.0L.
There is the perfect truck that this lady has down the street, she never drives it, it's a 2006 rcsb victory red, perfect cond, 4.3 5sp, do a 6.0 swap and the t56 swap is soooo much easier with a manual already in the truck, it's the perfect truck, SS red so just SS bumper and rollpan and toneau cover and it's a real SS.
Originally Posted by 1SlowHoe
Get either one and mill the heads/increase head gasket thickness to get the CR you want.
The LQ4s with the aluminum heads (317s) made 325 hp- Came in the C3s and Denalis and maybe others.
Originally Posted by gmforlife
I am going to be going to a junk yard and searching for some 6.0's, i haven't decided if i want the low compression 6.0 or the higher one, depends on what i want to build it for. But as i recall, the LQ4 is the 300hp lower compression motor and the LQ9 is the SS 345hp higher compression CORRECT??????
Anyway, i know you can determine which motor from a vin, but shoping for just the motor how can u tell which is which? Is there a block number i should be looking for? If someone could just let me know that would be great, i used to know and had the numbers written down but have lost them
True. If you think you will do nothing to the motor after you buy it, then hold out for the LQ9.
But, If you think you will build it up, then just make sure you get a 6.0l block with the good heads. I don't think you have an FLT 80e for 345hp though.
Buy it-Break it-Build it!
