How to determine 6.0's
#21
Originally Posted by sliderbkt
True. If you think you will do nothing to the motor after you buy it, then hold out for the LQ9.
But, If you think you will build it up, then just make sure you get a 6.0l block with the good heads. I don't think you have an FLT 80e for 345hp though.
Buy it-Break it-Build it!
#24
Originally Posted by usabodyguard
other than dished pistons, isnt the lq4 the same as the lq9?... get the cheaper lq4 and throw some diamond pistons in it... of course i could be wrong...
what the hell do i know...
#25
Denalis and C3s also had LQ9s, not LQ4s. AFAIK, SSS, Denalis, C3, Esky, and VHOs where the LQ9 equipped trucks. HDs and CCs where the LQ4s.
The only difference is rods and pistons and you'll be replacing both if you do a 408. Because of that, paying the extra coin for a LQ9 seems a bit silly. The LQ4 is 9.4:1 and the LQ9 is 10.1:1. If your buddy can get a 6.0 for $500, DO IT and worry about the pistons at rebuild time
#27
GMCtrk
18
Oct 6, 2015 03:48 PM
Cammed4ever
Sep 30, 2015 03:38 PM
