How can I level my ride?
Old Mar 16, 2004 | 09:42 PM
Buckwheat's Avatar
Default How can I level my ride?
I want to rid my truck of that jacked-up-in-the-back look. It's a 99' 2500 4x4 EC LB. It's not a Heavy Duty and has a near level stace when a about 1800lb camper is in the back. I got to looking at the leaf springs the other day and they rest on a spacer that separates them from the axle. The spacer is about 2" tall. I was thinking of just removing the spacers or if that aint a good idea to cut and reweld them to shrink em' down a little.
Any suggestions or tips?
Thanks
Old Mar 16, 2004 | 09:56 PM
parish8's Avatar
single digit dreamer
not 100% sure since you have a LD2500 but on the 1500's you can just pull out that block. you will need shorter u bolts though. i just got a set of u bolts from a 15002wd.
the other thing you can do is crank up your tortion bars a little, you can probably get close to 1" without messing up your ride much.
Old Mar 17, 2004 | 08:51 AM
Buckwheat's Avatar
Thanks. I'll do the rear first and maybe try the torsion bars if I still want more.
Old Mar 17, 2004 | 09:00 AM
If it's 4x4, then why lower the back? Crank up the torsion bars, it will look a lot better!
Old Mar 17, 2004 | 11:06 PM
Texas Terminator's Avatar
11 Second Club
throw a fat chick in the back.
Old Mar 18, 2004 | 05:42 PM
Buckwheat's Avatar
"No Fat Chicks"!
If I could lower the front and back, I would do it. Makes it a hell of alot easier to load the dirtbike or fourwheeler. I don't offroad with it at all... just need the 4wd for the winters. I measured today and there is a 3.5" difference in the gap from the top of the tire to the bottom of the wheelwell from front to back. If I can eliminate the spring perch I can get it down to about a 1.5-2" difference.
Old Mar 18, 2004 | 05:51 PM
parish8's Avatar
if thats what your shooting for you can do shackels too, that will give you another 1" in the rear.
i did the block removal and shackels for 3" in the rear and droped the front about 1" with the tortion bars, looks like a 2wd but has the 4wd launch, you will probably want to get an alignment when you get it to the height you want.
06droppedcrew
Nov 17, 2015 10:56 PM
cheyenne383
Nov 13, 2015 09:24 AM
dantheman1540
Nov 1, 2015 02:59 AM
GM1697
Oct 3, 2015 11:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
