Home Made Cold Air Intake?
Old Feb 2, 2004 | 07:34 AM
JSmith's Avatar
Originally Posted by Chingon
JSmith:
On that website, I see that 4" OD aluminum tubing that you used to connect the 45* and 90* rubber hoses together, how long was that piece of aluminum tube? 1 foot? That's the minimum length it says you can buy.
I bought 3 feet and cut the length I needed. My original plan was to go with as much aluminum tubing as possible but I couldn't find anyone to mandrel bend it and I couldn't run it straight to the airbox.
Also, from the 45* rubber hose to the rubber "accordian boot" what is that? More of that 4" OD aluminum tubing?
Yep.
What I'm looking to do is run the MAF right in front of the TB so I can put a nozzle on one of the rubber hoses for a dry kit setup.
I saw Oxidizr's dry setup when I went to get my Magnaflow cat-back, but it's been awhile. It looks similar to yours but his has the MAF on the TB.
I may end up putting the MAF in front of the TB if I ever get around to making a second intake system. I think a 4" to 3" rubber reducer would work well for that if it isn't too long.
shawn96gmc
May 17, 2016 04:15 PM
noproblems209
Aug 10, 2015 06:57 PM
rudvirus
Aug 5, 2015 08:05 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 14, 2015 02:10 AM
