Home Made Cold Air Intake?
Old Jan 31, 2004 | 11:38 PM
Default Home Made Cold Air Intake?
Has anyone ever made one? I have made one for a Dakota and for my old Grand Prix just wonder if it has been done for our trucks.
Old Jan 31, 2004 | 11:39 PM
ThunderZ28's Avatar
12 Second Club
BIGTEX made one for his just do a search on him and you should be able to find some pics.
ThunderZ28's Avatar
12 Second Club
his looks pretty good to.
Old Feb 1, 2004 | 01:11 AM
JSmith's Avatar
I made my own too.
Old Feb 1, 2004 | 04:06 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
JSmith, could you give a list of what you bought?
I just see piping, clamps...how did you connect the 2 pipes?
What's that stuff right after the MAF?
Is that tin foil on the air box?
Old Feb 1, 2004 | 11:54 AM
Originally Posted by JSmith
I made my own too.
JSmith! Where did you get the rubber accordian boot that connects the tube to the MAF?
Jim
Old Feb 1, 2004 | 11:56 AM
MHLY01's Avatar
There are different ways to put it together. One way is to use a 4" 90' rubber elbow to hook up the the TB and turn to the airbox. Then a 4" metal tube to the MAF, either angles or staright, and you can use the stock accordian connector to it or us a 4-3.75"
Other way is to use couplers to connect a 4" short radius mandrel elbow to the TB then a coupler and 4" tubing to the MAF and then use a reducer at the MAF to connect it.
The only problem with the big 4" intake tubes and making your own is that you will have to use electric fans. There is no way to get a 4" shirt radius bend elbow of any type to fit between the Radiator and TB as there is only 5" clearance stock. That is why there is a kink in the stock tube to make it fit.
You can get every part you need at:
http://shop.airflowonline.com/Merchant2/merchant.mv
They have great service and are much much cheaper then most places plus they have aluminum coated tubing. Their high quality T-clamps are only $4 compared to most turbo shops that sell the same thing at $6-10
Old Feb 1, 2004 | 01:30 PM
JSmith's Avatar
I got everything at Airflow Systems Inc.
Parts include:
4" 90 degree rubber elbow
4" 45 degree rubber elbow
4" Aluminum tubing
4" Premium clamps
The two rubber elbows are joined by a 4" long piece of that aluminum tubing inside. All the aluminum tubing used has the edges rounded and polished inside. The "tin foil" looking stuff around my airbox is actually heat reflective material. It reflects radiant heat and it works quite well actuall. I still have to get heat wrap and wrap the tube.
Jim
That's the corrugated tubing from my stock intake tube. I'm trying to find a way to not use it though.
Ding, ding, ding, ding, ding! You won the prize!
That place has awesome stuff for do it yourself intake projects. I think my next go at it will be full 4" aluminum and have it bent to my needs. Only if I can find a place that can bend a 90 degree into that large of tubing without it creasing.
Old Feb 1, 2004 | 02:32 PM
MHLY01's Avatar
That was my problem, no exhaust shops, machine shops, or diesel shops around me could bend the 4" tubing, most were only good up to 3". I am going to modify my whole ATI system, we see what happens.
Old Feb 1, 2004 | 07:23 PM
JSmith:
On that website, I see that 4" OD aluminum tubing that you used to connect the 45* and 90* rubber hoses together, how long was that piece of aluminum tube? 1 foot? That's the minimum length it says you can buy.
Also, from the 45* rubber hose to the rubber "accordian boot" what is that? More of that 4" OD aluminum tubing?
What I'm looking to do is run the MAF right in front of the TB so I can put a nozzle on one of the rubber hoses for a dry kit setup.
I saw Oxidizr's dry setup when I went to get my Magnaflow cat-back, but it's been awhile. It looks similar to yours but his has the MAF on the TB.
