help no oil pressure
Well. I started looking oil pressure. Was running fine with 40 psi while idling started dropping fell to 20 psi. All of the sudden 0 psi. Took off the oil cap and neck and I'm getting no oil to top. The motor started knocking. A pretty good tap. Checked the oil pump looks good nit sure what I suppose to look for but gears looked good. This is a 4.8 06 with probably 70k miles.dont get me wrong this engine has been through a lot. Nitrous boost several cam swaps etc Could it be the lifters. I was searching and it can possibly be a spun bearing. Is there anyone that can point me to the right direction. Thanks.
Can't seem to get the Damn oil pan separated to the engine. I removed all bolts to the pan. Am I doing something wrong. We swapped out the oil pump to my brothers 6.0 last year can't seem to remember what we did different
