Help me identify my metal shavings!!
Old Nov 14, 2006 | 10:32 PM
thunder550's Avatar
High on diesel fumes
Default Help me identify my metal shavings!!
So....I pulled the oil pan to change my oil pickup tube o-ring (low oil pressure problem), and I got a little surprise!!
Any idea what these are from? Some are metal and magnetic and some are not metal. None were stuck to the oil pan drain plug. Spun bearing? I didn't have any weird engine noise.
Old Nov 14, 2006 | 10:44 PM
FarmerBeau's Avatar
Sexy Party Mod
That does look like bearing material. Cut open your oil filter and see what you can find.
Old Nov 14, 2006 | 11:00 PM
thunder550's Avatar
Oil filter is clean inside
Old Nov 14, 2006 | 11:17 PM
phasemaster1's Avatar
piston skirt or just casting material?
Old Nov 14, 2006 | 11:23 PM
thunder550's Avatar
I can hope for that.....seem to big and too many to be something normal....
I pulled the windage tray but don't see anything obvious. Everything looks clean without tearing into the motor any more...
Old Nov 14, 2006 | 11:24 PM
TurboGibbs's Avatar
That is hard to tell believe it or not. Those are pretty good pics. Maybe a few more details of individual pieces at different angle on your finger tip? It is hard to tell in 2 deminsions. Also, which ones exactly are magnetic and which are not?
Old Nov 14, 2006 | 11:26 PM
thunder550's Avatar
Question....if I pull the bearing caps and the bearing is good, do I still need to replace it? Or can I just put the cap back on it?
Old Nov 14, 2006 | 11:27 PM
thunder550's Avatar
The shiny ones are metallic, and the darker ones are not even metal (or don't feel like it). The dark ones are brittle and not magnetic.
I wonder if thats from your oil pump? causing low oil pressure and not o-ring.
Old Nov 14, 2006 | 11:30 PM
When i removed my pan i recall having a couple of the dark one's myself they looked like plastic. but no metal like that.
