help me guys (swap problems)
Old May 22, 2009 | 07:02 PM
03lowriderss's Avatar
Default help me guys (swap problems)
Hello to all, today i went to my dads shop to finish up my 5.3 to 6.0 swap, got everything bolted up with the exception of the lpp y pipe and i didnt hook up my o2 sensors.
i went to the cab and primed the fuel cranked it over and it fired to life.
the dash said Reduced engine power it was also revig high idle.
i turned the key off and the engine kept on running for about twenty seconds.
thought it may be a fluke, i started it back up... no good same thing.
is this something any body else has ever had happen?
and my gas pedal/throttle doesnt work
Old May 22, 2009 | 08:42 PM
2005 Silverado's Avatar
SPAM HUNTER
Was computer or anything changed. I have never heard of run on after the key is off (with the newer stuff unless electrical issue)...Possible ground issue. Did all grounds get bolted up?
Dustin
Old May 22, 2009 | 09:08 PM
i think that the ground have been grounded, yes i had Nelson retune it for the 6.0
Old May 24, 2009 | 10:47 AM
Great no one knows?
Any speculators, just want a good place to start diagnosis..
BLAKE
Old May 24, 2009 | 01:48 PM
SilverDog's Avatar
When I first bought my truck I had issues were it wouldn't start and occasionally showed the "Reduced Engine Power". They replaced everything. They fixed the problem after the truck left me stranded three times. They stated the problem as being a bad/loss fuss block(one in engine bay). Not sure it this helps. I know it's not fun but I would double check all wires.
Old May 24, 2009 | 02:04 PM
Raffman's Avatar
I would go over the grounds again, there's a bunch of em and the ones on the back of the motor are hard to see. I assume everything is drive by cable?
Old May 24, 2009 | 08:01 PM
budhayes3's Avatar
PT's Slowest Truck
Make sure that the connections to the throttle body are good, and that there aren't any pins bent or anything like that. Triple check all of the grounds as mentioned above also.
Old May 24, 2009 | 11:50 PM
i assume they can ground on the back of the heads, i recall hooking up two there. i will start with the gounds and see where that takes me.
Old May 25, 2009 | 11:57 AM
Really strange. Is this fly-by-wire or cable?
Old May 25, 2009 | 11:58 AM
Really sounds like a ground or you didn't hook something up. Did you say you double and triple checked everything?
