Help with E-Fans
Old Mar 12, 2004 | 09:50 AM
Scarab's Avatar
Thanks again for all the help you guys are great.
Old Mar 12, 2004 | 10:23 AM
ThunderZ28's Avatar
12 Second Club
Old Mar 12, 2004 | 08:10 PM
agreif's Avatar
http://james.jaguar.net/agreif/fans/fanstech.htm
Old Mar 12, 2004 | 08:46 PM
GREGGO's Avatar
Nice write-up!
Old Mar 12, 2004 | 08:58 PM
agreif's Avatar
Thanks, got an eaton posi one too for anyone who needs it. See the homepage.
Old Mar 13, 2004 | 12:34 AM
Make sure you do tap into the AC lines. Running the AC without the fans on at a stop can actually build up enough pressure in the system to blow the AC lines (usually around the condensor). Good luck!
Old Mar 13, 2004 | 01:27 AM
eallanboggs's Avatar
I tapped into the DARK GREEN wire that enables the A/C relay. I used that wire to turn ON a relay that is one of the enables for my fans. The other is a Flex-a-lite Adjustable Thermostat which goes to another relay. This way my fans come on when the water temp at the radiator inlet neck is 185 degrees OR the A/C compressor kicks in. I soldered in waterproof fuse holders for everything to finish off the job. It works real well and the Meziere electric water pump keeps my engine so cool that the fans only work about half the time.
thunder550
Oct 8, 2015 04:53 PM
old motorhead
Sep 29, 2015 08:22 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
2000_Silverado_SS
Sep 18, 2004 09:02 AM
