Help with E-Fans
Old Mar 11, 2004 | 10:23 PM
Scarab's Avatar
Default Help with E-Fans
I am helping a friend hook up e-fans and wanted to know where are ya'll are taping in for your ignition on wire at. Also, hook up to a/c or no just let temp switch do its job.
Old Mar 11, 2004 | 10:48 PM
FarmTruc's Avatar
Performance Trucks Sponsor
what brand of efan, ls1 or the flex fans?
find any power ignition on hot wire and that will work.
Old Mar 11, 2004 | 10:56 PM
ThunderZ28's Avatar
12 Second Club
got mine on both temp and a/c
anytime i turn the a/c on the fans are on.
came off of the fuse box there in the engine compartment. there is a terminal that becomes hot when you turn the key on. check it with a meter and you will find it.
Old Mar 11, 2004 | 11:00 PM
Scarab's Avatar
Thanks for the help. They are LS1 fans. Is there a wire in the fuse box for A/C
Old Mar 11, 2004 | 11:07 PM
ThunderZ28's Avatar
12 Second Club
do a search, i cant remember off hand what wire it was, think it was green. but not positive. just do a search on ls1 fan wiring.
Old Mar 11, 2004 | 11:30 PM
HAZE's Avatar
just probe both the wires going to the ac compressor plug while someone hits the switch [make sure the fan switch is on] if i remember correctly it only powers on for a few seconds. for ign on power i tapped a fuse in the fuse box under the hood [its just a trigger and doesn't draw much current. you can get a fuse tap at your local auto parts store.
Old Mar 12, 2004 | 12:37 AM
Flyer's Avatar
Yes ... the wire is green. It is in the fuse panel, in the middle section somewhere I think. It's been a while since I've been in there, but I think that's where it is.
Old Mar 12, 2004 | 12:42 AM
bigguy75inches's Avatar
take off the fuse block cover, press the release clip holding the front of the fuse block and it will hinge up. find the ac relay on the fuse block and then look under the fuse block in the gereral direction and look for the darkest green wire, i also believe it has a white stripe on it. that is the signal wire for the ac compresser. when i installed my flexalite fans, it went to the negetive signal connector. hope it helps! also, i got my ignition from one of the fuses up top, it was in teh certer called ignition i believe. the best thing is to have a test light and take out the fuse, use teh test light to see if it gets power with the key on, and no power when the key is off. good luck
Old Mar 12, 2004 | 12:43 AM
and if your really desperate, i will take some pictures whatever you need to know tomorrow.
Old Mar 12, 2004 | 08:51 AM
black_yukon's Avatar
I think any of the pink wires in the fuse box are "ignition on" wires. There are a lot of them under there, so take your choice, but just check it with a test light first.
