Heads & Cam & Radix Question
Old Jan 4, 2009 | 02:25 PM
airforcefun's Avatar
Default Heads & Cam & Radix Question
Hello,
what heads and cam combo would best compliment the radix kit? How much HP could i expect to make? What stall would i need I need to get? What trans does a 2wd 01 tahoe tahoe come with? What size is the rear end in the 01 tahoe?
thank you very much,
Justin
Old Jan 4, 2009 | 02:33 PM
mds2004's Avatar
Others can help you with the first few questions. You would have a 4L60E and a 8.5" 10 bolt.
Old Jan 4, 2009 | 02:37 PM
mds2004's Avatar
As for Cams, here is a Lingengelter Gt2-3 http://www.lingenfelter.com/store/l210085297.html and a GT7 http://www.lingenfelter.com/store/l210095297.html
The GT2-3 seems to be more popular.
Old Jan 4, 2009 | 04:58 PM
silveradol33's Avatar
8.6 10 bolt.
Old Jan 4, 2009 | 05:17 PM
mds2004's Avatar
Originally Posted by silveradol33
8.6 10 bolt.
Doh, thats what I meant. Thanks for the clearup.
Old Jan 4, 2009 | 05:28 PM
terravast4's Avatar
I have the GT-2-3 and am planning on matching that with the prc stage 2.5, 5.3 heads. They flow 312@.600 and they just lowered thier prices to $1134.99 for the set so that is a steal in my opinion.
Old Jan 4, 2009 | 06:04 PM
PSM's Avatar
PSM
+1 for the gt2-3 cam.
I stayed with a stock converter but if you do go with a aftermarket verter, I'd stick with a 2400-2600 stall. Try a Precision Industries or Yank for converters
Old Jan 4, 2009 | 08:36 PM
thanks for the info. how much hp will this setup make?
Old Jan 4, 2009 | 10:07 PM
terravast4's Avatar
it is really based on your supporting mods but are you after a HP# or a track time?? if you run a big converter you may not show great dyno numbers but you will have great luck at the track. It is really different for every combo.
The_W
Oct 28, 2015 09:00 PM
JFortner5
Aug 12, 2015 08:46 PM
steves86ta
Jul 28, 2015 10:21 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
