Headers Questions
Old Jul 21, 2005 | 05:54 AM
ajwz28's Avatar
Default Headers Questions
I Have A 02 2500hd Extcab Short Bed Does Anyone Make Long Tube Headers Or What Is The Best Headers To Get. And Can You But A Trailblazer Converter In It
Old Jul 21, 2005 | 06:25 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
No you cant put a tb converter in it your truck has a 4l80e in it and thosse converters aer for 4l60e's. Stainless works, dynatech, I believe arizona speed & marine and pacestter make them for your truck.
Old Jul 21, 2005 | 09:43 AM
ajwz28's Avatar
No One Makes A Y-pipe Does Any One Know How Does Or Where I Can Get One Made
Old Jul 21, 2005 | 10:16 AM
Mort's Avatar
Cool
Your truck does not have a y-pipe it has duals back to the muffler. Dynatech makes headers and tubes with cats in them. Some fabrication to join the tubes to your cat back may be required. They are not cheap but you get SS headers and tubes with cats. Or just get the headers and have the existing exhaust modified to bolt up. Have a look at them here Dynatech . You may need a good exhaust shop in your area to connect your existing exhaust to the headers or your cat back to the tubes with the cats in them.
Also TOG ( The Other Guys ) makes a nice set of mid-length headers that a lot of people seem to be happy with.
Old Jul 21, 2005 | 04:04 PM
closet red neck's Avatar
Get the Dyanatech Header System. This is the best system out there, IMO!!!! It is a direct bolt on. Thats what I have on my truck.
Old Jul 21, 2005 | 04:09 PM
1slow01Z71's Avatar
He has an hd they have a different exhaust setup than the half ton trucks. They are good headers jsut not worth the money IMO and alot of others.
Old Jul 21, 2005 | 04:24 PM
Leroy_454's Avatar
No one that I know of has a direct bolt on kit for an HD truck. The HD does not have a Y pipe, but has larger diameter dual pipes than the SS, Escalade, and Denali's. I am not sure, but it looks like the dynatech system for 6.0L engines has 2.5" head pipes. I believe the 2500 HD trucks have closer to 2.75" stock. I would just order headers with a 3 inch. collector and get a custom setup built to adapt your stock cat pipes to the new headers. If 2.5" header collectors are adequate for your truck, you could just expand the adapter pipe to fit inside of your stock 2.75" piping.
Old Jul 21, 2005 | 04:35 PM
ajwz28's Avatar
ok if long tubes are a b*tch what are the best mid or short length headers
and has any one but a head and cam package on these and has anyone but a ls1 or ls6 intake on them (2500hd 6.0)
zblee
63
Jun 10, 2023 01:25 PM
2500ZL1
Jan 25, 2016 06:30 AM
Stainless Works
13
Nov 5, 2015 03:31 PM
Martin4_8
Aug 13, 2015 07:31 PM
USMCvet0311
Aug 1, 2015 07:45 AM
