Header install troubles.....
Old May 12, 2008 | 09:45 PM
YenkoST's Avatar
Default Header install troubles.....
Got a pair of the Edelbrock shorty headers. Passenger side went in fine with no problems....went to the driver side, got the manifold bolts off and 1 collector bolt. Went to the next two and they both stripped and won't budge. So, I took a dremel to one of the nuts but got some of the material off of it but still can't get that one off. Is my only option at this point to take a saw to the pipe and cut it off and let an exhaust shop weld it all back up?
Old May 14, 2008 | 10:55 PM
Regency04's Avatar
no you could torch the bolt nut off split the with a chesel or a nut splitter
Old May 14, 2008 | 11:17 PM
00ChevyScott's Avatar
Wearin' da big hat
Deep Creep at your local O'reillys or Auto Zone.
worth every penny. I know your nuts are stripped, but this will help loosen things up a bit.
Old May 15, 2008 | 07:26 AM
YenkoST's Avatar
That's what I used is Deep Creep. I got them off with a lot of grinding. Thanks for the help anyways.
zblee
63
Jun 10, 2023 01:25 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
2500ZL1
Jan 25, 2016 06:30 AM
mrhino
Aug 7, 2015 10:01 AM
zblee
Aug 3, 2015 03:45 AM
