Header install help....
Old Sep 26, 2007 | 10:47 AM
10RamSport's Avatar
Formerly 08_gmc_slt-08/20/2010
Default Header install help....
Ok, my dilemma , I recently bought Pacesetter Long tubes for my 05 Sierra 5.3. My goal is to not break the bank on this but I have called every muffler shop in the phone book and none of them install headers! I was wondering if anyone has any suggestions? Should I install them myself to save $$? How hard is the install? Will I get SES lights on all the time as I have been warned? What happens after the install, i.e. what exhaust work from there is needed?
I am almost to the point of returning them and saying
Old Sep 26, 2007 | 11:01 AM
Silver-Dollar's Avatar
You can install them yourself, tossed the y-pipe and catback into the back of the truck, drive it or tow it, and have the muffler shop do the rest. You will get a SES light unless you have the back cats turned off by tune already, but it should not effect anything. Driving the truck to the shop may cause unwanted attention.
Most will not do headers because of the bolts going into aluminum heads. If they break a header bolt, it will cost them more to repair it than the install itself. It is not worth the risk for most places.
Old Sep 26, 2007 | 12:48 PM
MonsterZ28's Avatar
do it all yourself, its easy as hell. Pacesetters and ORY hook right up to your catback
Old Sep 26, 2007 | 01:26 PM
It took me 3 hours. It's easy if you can get your truck on a lift and get it high up so you can work on it. Just unplug all your spark plug wires and take your plugs out and I disconnected the intermediate steering shaft and they went in nicely from the top but I had a guy helping me under the truck too!
Old Sep 26, 2007 | 02:10 PM
MonsterZ28's Avatar
All i did was take the truck up on ramps and take off the spark plug wires. Headers went in and out from the bottom
Old Sep 26, 2007 | 02:55 PM
viciousknid's Avatar
Where's the Beef?
Everything they said.
https://www.performancetrucks.net/fo...d.php?t=401206
Old Sep 26, 2007 | 03:13 PM
thunder550's Avatar
High on diesel fumes
I don't understand why everyone has so many problems with the header bolts. I have installed and removed mine so many times I can't remember anymore, and never once had a problem with the bolts. As long as you make sure they are not cross-threaded before you crank them down, and tighten them to spec (11lb-ft first pass, 18 lb-ft second pass) there should never be a problem.....
Old Sep 26, 2007 | 09:27 PM
I was always thought the flange had to be welded on and the y pipe fabbed for Pacesetters. I guess not if everyone is doing them in their driveway.
Old Sep 26, 2007 | 10:36 PM
thunder550's Avatar
Pacesetter LT's and ORY are slip-fit. No flange to weld.
Old Sep 26, 2007 | 10:47 PM
Stoichiometric's Avatar
If you plan to pull them off once or twice the ARP header studs are nice to have. I have re-used stock bolts without problems, use anti-seize.
zblee
63
Jun 10, 2023 01:25 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
2500ZL1
Jan 25, 2016 06:30 AM
mrhino
Aug 7, 2015 10:01 AM
zblee
Aug 3, 2015 03:45 AM
