header install
Originally Posted by sixliterhd
Mine took 3 hours with a 30 min bullshit session/ parts run.
Stock up in WD40 and spray th hell out of the bolts.
I've read on the other header threads that WD-40 doesn't work well....it's not a penetrating lubricant.
what about the install of the ORY?? or for those of us who dont weld, would it be best ot leave it open header and saw the exhaust off and drive it to the local muffler shop to have them weld the ORY on?
The install doesn't take that long. You do have to remove the old exh manifolds and cat Y pipe. That takes a while. You need some good jackstands to get the truck high enough off of the ground to make it easy to work under and a good creaper helps big time. The two sets of Pacesetters I did recently went in easy from the bottom. It helps if you have someone around to get the two end flange bolts started and then you can finish by yourself. I put never seize on all of the slip fittings. It helps when your sliding everything into position because it's so slippery and it is also supposed to help if you ever have to remove them in the future which I'm hoping never happens. The OR Y pipe bolts right up to the stock muffler flange. Nice. With those long tube and OR Y pipe and aftermarket dual rear outlet catback with a big cam and stageII heads my truck sounds bad as hell. When I ride thru a parking lot all the alarms go off. It's like what happens at an NHRA race when the fuel cars run. When they shut down at the finish line you can hear all the alarms echoing from the parking area.
Originally Posted by Soon2bSpooled
why is it so hard to install those things,i know they are probably heavy and a might big but does size warrant 5 hours or work? does this include the ORY and stuff too? the reason i ask is ill be getting those SOMETIME and want to know if i can do it myself alone since my dad is useless and most other buddies are not into this type of thing
zblee
63
Jun 10, 2023 01:25 PM
zblee
Aug 3, 2015 03:45 AM
