header install
Old May 6, 2006 | 06:48 AM
BradS's Avatar
Mine took 3 hours with a 30 min bullshit session/ parts run.
Stock up in WD40 and spray th hell out of the bolts.
Old May 6, 2006 | 04:45 PM
stone150's Avatar
i'm wondering this too!
Old May 6, 2006 | 04:49 PM
TarheelZ's Avatar
Originally Posted by jm's customs
its not the headers that will give you the problems its everything else.
Old May 6, 2006 | 05:38 PM
Colby 04's Avatar
I've read on the other header threads that WD-40 doesn't work well....it's not a penetrating lubricant.
Old May 6, 2006 | 05:47 PM
99Silver6.0's Avatar
Blaster kicks ***!!
Old May 7, 2006 | 12:34 AM
what about the install of the ORY?? or for those of us who dont weld, would it be best ot leave it open header and saw the exhaust off and drive it to the local muffler shop to have them weld the ORY on?
Old May 7, 2006 | 02:23 AM
eallanboggs's Avatar
The install doesn't take that long. You do have to remove the old exh manifolds and cat Y pipe. That takes a while. You need some good jackstands to get the truck high enough off of the ground to make it easy to work under and a good creaper helps big time. The two sets of Pacesetters I did recently went in easy from the bottom. It helps if you have someone around to get the two end flange bolts started and then you can finish by yourself. I put never seize on all of the slip fittings. It helps when your sliding everything into position because it's so slippery and it is also supposed to help if you ever have to remove them in the future which I'm hoping never happens. The OR Y pipe bolts right up to the stock muffler flange. Nice. With those long tube and OR Y pipe and aftermarket dual rear outlet catback with a big cam and stageII heads my truck sounds bad as hell. When I ride thru a parking lot all the alarms go off. It's like what happens at an NHRA race when the fuel cars run. When they shut down at the finish line you can hear all the alarms echoing from the parking area.
Old May 8, 2006 | 07:53 AM
jm's customs's Avatar
Originally Posted by Soon2bSpooled
why is it so hard to install those things,i know they are probably heavy and a might big but does size warrant 5 hours or work? does this include the ORY and stuff too? the reason i ask is ill be getting those SOMETIME and want to know if i can do it myself alone since my dad is useless and most other buddies are not into this type of thing
when i did mine it was just the headers, it wasnt that bad and this was the first time iv done something like this. i know what you mean i was hopping my dad would come out to the shop and help, yeah he was snoring about 30 min after i started. do it on the weekend so there might be someone that could help. i did mine on thur and everyone i knew had work or school in the morning so i was screwed. a second person would have been nice but not hard to do you self.
Old May 8, 2006 | 10:42 PM
good deal after the cam i may just be ordering some headers
zblee
63
Jun 10, 2023 01:25 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
2500ZL1
Jan 25, 2016 06:30 AM
mrhino
Aug 7, 2015 10:01 AM
zblee
Aug 3, 2015 03:45 AM
