Head gaskets ..
I've popped another set. This makes the 2nd set I've been through with the 6.0 heads on the 5.3. COuld it be the difference in bore size popping the gaskets or what? I'm using the 6.0 gaskets, and I really don't htink I'm at the power level of gaskets being a problem.
I'm really wondering if it's those damned studs backing off. It seems like I've read of that in the internal setion, but that was long ago if it was.
It's rough on a cold start, but once it warms up, it's perfectly fine. I don't get it.
I have heard that the MLS gaskets arent as good for high cylinder pressures (boost, n2o) as graphite gaskets. As far as I know GM only makes a MLS for the 6.0 so you may have to go with a Cometic. :dunno:
I am using the MLS gaskets. I've heard that Cometics don't seal real good unless you've decked the block and heads. :???: That's the 1st I've heard of them not sealing though, the MLS's that is.
Anyone know what gaskets Parish was/is using?
I've thought about the FelPro's but I dunno. I really don't wanna do this a 3rd time. I'd like to go ahead and build the ls1 to put in it, that way I would be able to start over fresh, but funds are to tight right now.
BIGD4504
Jul 28, 2015 11:46 AM
