Head gaskets ..
Old Apr 27, 2005 | 12:03 AM
Flyer's Avatar
Default Head gaskets ..
I've popped another set. This makes the 2nd set I've been through with the 6.0 heads on the 5.3. COuld it be the difference in bore size popping the gaskets or what? I'm using the 6.0 gaskets, and I really don't htink I'm at the power level of gaskets being a problem.
I'm really wondering if it's those damned studs backing off. It seems like I've read of that in the internal setion, but that was long ago if it was.
It's rough on a cold start, but once it warms up, it's perfectly fine. I don't get it.
Old Apr 27, 2005 | 12:15 AM
F8L Z71's Avatar
I didn't have problems with mine and you know the power level I was at.
I don't think Jim did either.
Mine were studded. Are yours or just bolts?
Old Apr 27, 2005 | 12:18 AM
moregrip's Avatar
what a rush!
what gaskets you using?
Old Apr 27, 2005 | 07:50 AM
Flyer's Avatar
ARP studs, first time torqued to 70 like they say, 2nd time torqued to 75.
They are GM 6.0 geaskets.
Old Apr 27, 2005 | 10:23 AM
BigKID's Avatar
I have heard that the MLS gaskets arent as good for high cylinder pressures (boost, n2o) as graphite gaskets. As far as I know GM only makes a MLS for the 6.0 so you may have to go with a Cometic. :dunno:
Old Apr 27, 2005 | 12:06 PM
Flyer's Avatar
I am using the MLS gaskets. I've heard that Cometics don't seal real good unless you've decked the block and heads. :???: That's the 1st I've heard of them not sealing though, the MLS's that is.
Anyone know what gaskets Parish was/is using?
I've thought about the FelPro's but I dunno. I really don't wanna do this a 3rd time. I'd like to go ahead and build the ls1 to put in it, that way I would be able to start over fresh, but funds are to tight right now.
Old Apr 27, 2005 | 01:30 PM
OBXMarine's Avatar
I remember seeing Parish say he overtorqued his by 15lbs after lifting his heads twice I believe. Not sure of his gaskets.
Old Apr 28, 2005 | 06:23 PM
OBXMarine's Avatar
TTT... hoping Mr. Torque will chime in...
Old Apr 28, 2005 | 07:20 PM
KySilverado's Avatar
Heads and deck flat?
Old Apr 28, 2005 | 07:32 PM
sleepersilverado's Avatar
i had a problem with the mls gaskets on my truck then changed to the graphite and so far so good.
lsxperformance
Apr 20, 2016 12:17 AM
thunder550
Oct 8, 2015 04:53 PM
JordanH
Aug 8, 2015 07:59 PM
BIGD4504
Jul 28, 2015 11:46 AM
