Has any succesfully got a header in from the top on the drivers side?
Old Oct 28, 2008 | 10:42 PM
  #41
dlt76028's Avatar
i got GM performance jack stands and jack at walmart for $40
Old Oct 28, 2008 | 11:50 PM
  #42
GMCtrk's Avatar
wtf? I saw the GM performance 3 ton jack for $99 @ walmart.
Old Oct 29, 2008 | 09:33 AM
  #43
dlt76028's Avatar
i got a 2.5 ton and it was $20. they also had a 2 ton and a couple different sets of jacks, try another walmart...
Old Oct 29, 2008 | 09:47 AM
  #44
krambo's Avatar
alright then I wont worry about the torque wrench. I never had any problems just tightening them down snug. Let's just hope none of the 8 bolts snap on me. I've still got one lodged inside my head partially
Man, 5 pages in one day on this post! Anyway, do not forget your antiseize on the header bolts. I did not use a TQ wrench, just a box end and however tight I could with my hand. As mentioned, start with the inner bolts first and just snug them, as you work out. When they are all snug, go back and tighten them down in the same manner (inner to outer). If they come loose, just retighten...its much better than snapping one off.
FWIW, I made my own "ramps" out of 2x12 pressure treated lumber. Sandwhich 3-4 layers and you have one hell of a sturdy platform. Make some chocks for added security and also apply the E-brake. Be safe.
Old Oct 29, 2008 | 02:39 PM
  #45
GMCtrk's Avatar
Yep I got hi temp anti seize! thanks for the post
Old Oct 30, 2008 | 10:23 AM
  #46
jakebdb56's Avatar
Driver side on mine went in from the top easier and fits better than the passenger side. I did have to just bend that battery bracket forward just a little. Just antiseize the bolts and tighten them down.
What gaskets did you end up using?
Old Oct 30, 2008 | 01:02 PM
  #47
POPO1984's Avatar
i just put mine in right now using the factory gaskets. only problem i have is the spark plug wires are touching the headers on the driver side the two ones closest to the back. Does anyone else have this problem
Old Oct 30, 2008 | 01:04 PM
  #48
00ChevyScott's Avatar
Wearin' da big hat
Mine have touched before for long periods of time and have not had any problems. As long is it is the boot touching, and not the wire itself, I doubt you'll have problems either.
Old Oct 30, 2008 | 01:12 PM
  #49
jakebdb56's Avatar
, if you get some OEM replacement wires from RicerZone they work much better as the dimensions are slightly different.
Old Oct 30, 2008 | 01:49 PM
  #50
POPO1984's Avatar
Ok cool I just zi tied them for now. Any tips for the driver side it looks like you gotta remove the starter or something for it to go in. I have been trying for 30 minutes
