Has any succesfully got a header in from the top on the drivers side?
Old Oct 28, 2008 | 07:11 PM
GMCtrk's Avatar
Default Has any succesfully got a header in from the top on the drivers side?
It looks like the little red power box and wire loom going to the intake is impeding. I can remove the red box and see if that gives me enough room.
Old Oct 28, 2008 | 07:12 PM
RandomHero's Avatar
why is it a big deal? Why don't you just put it in from the bottom?
For once I'm not trying to be a dick, just legitimately curious.
Old Oct 28, 2008 | 07:13 PM
Mangled03gmc's Avatar
Baltimore Whore
The bottom is best, take your inner fenders and tires off and it will make it even easier..
John
Old Oct 28, 2008 | 07:17 PM
JakeBrakeIH's Avatar
i would think the steering shaft would be a PITA also...bottom worked great for me!
Old Oct 28, 2008 | 07:21 PM
GMCtrk's Avatar
I dont have a jack. I saw some plastic ramps at Walmart, but they were $43. I'm a cheap ***
Old Oct 28, 2008 | 07:22 PM
budhayes3's Avatar
PT's Slowest Truck
Yea man, the bottom is your best bet, it's a piece of cake that way...you have to go down there to do the collectors and y-pipe anyway. I'm assuming that you're trying the top because you're on jackstands and might be having problems getting the truck high enough?
Old Oct 28, 2008 | 07:23 PM
Baltimore Whore
well it will be worth the headache if ya can get it up in the air to get them up from the bottom
John
Old Oct 28, 2008 | 07:24 PM
BlackGMC's Avatar
Resident Retard
Maybe he does not have a jack or jack stands??
Old Oct 28, 2008 | 07:32 PM
drkblusierra's Avatar
I have, i did disconnect the streering shaft in were they meet and i beleive the red power box, which is easy enough with its two bolts... as i remember, the drivers side was easier than the passenger but i believe it was the shape of the header... these are Pacesetter LT's i was installing. But i also have done it from the bottom up, which was much easier.
v8
17,16,15,14,13,12,11 Drvr
its a piece of cake on the drivers side, just mark the driveshaft at the coupling, use a 15mm wrench then push up the shaft towards the steering column, slide header in place, put a few bolts in and hook up collector, then tighten bolts on header, good luck.
