Has any succesfully got a header in from the top on the drivers side?
#54
Ok Guys i got them all installed and i took it to a muffler shop and the made the obx y pipe fit onto my stock collector at the tailpipe right before the muffler... I have to say though i am not to happy with by exhaust tone now i was hoping for a little more aggressive sound than what it has now...i might switch to a different muffler
#55
#56
Put a cutout, that will make it pretty aggressive
Anyways, today I accomplished a lot. I got my pipe expanded so that the pipes now properly fit together. And after a trip to NAPA, home depot, and 2 auto zone's I finally found 2 M18x1.5 oil drain plugs to block off the 2 wideband bungs
#59
The headers didnt' come with the plugs? Typically they'll come with a plug if it's an extra bung that's not for the stock narrowband sensors. Glad you got it installed fine and it's running. A Borla XR-1 would add some tone to the exhaust no doubt
#60
It's not in yet. I've started removing the stock exhaust. This is a bitch. I'm working with just a random *** set of hand tools. Now I have to hit up walmart because my adjustable box wrench wont fit around the around the 02 sensor nut. I also broke one of the 02 sensor wire connector clips dur. And I don't have the right size socket to get 1 of the collector nuts off (the others were a little looser to the point where a slightly bigger socket would take them off). Also, I'm thinking this will be a 2 day job for me. Everything hinges on whether or not I can get the Y pipe out without the crossmember going out. If the x member has to come down I'll have to take it to some friends that's beyond the scope of what I can do in my apt. parking lot.
