Guys with Magnaflow Y-pipes and X-pipes check the welds for leaks...
Old Dec 26, 2007 | 06:39 PM
BlackGMC's Avatar
Resident Retard
Default Guys with Magnaflow Y-pipes and X-pipes check the welds for leaks...
I have been chasing a weird lean condition while trying to tune my truck. It all started after I put the new Headers and exhaust on.. Anyways I finally found it. The factory welds on the Magnaflow Y-pipe are busted/leaking.... The black areas on the pictures below is where it was leaking... The only real reason I found it was I was looking at it this morning when I was warming it up and I noticed water dripping out of the welds...
Kinda sucks when you buy a piece from a good brand it is sucks!!! Anyways while I had the exhaust off, I decided to smooth down the welds and paint it. I got tired of grinding after doing the Y-pipe so I just left the rest... The kinda of crappy thing is that with paint on the pieces it makes the welds stand out more ....
Old Dec 26, 2007 | 07:03 PM
riddick1224's Avatar
What did u paint it with? Is it a high heat paint?
Old Dec 26, 2007 | 07:06 PM
BlackGMC's Avatar
Resident Retard
Yep, Dupli-color High Temp supposedly up 1200*, I did not know it was that shiney...
Old Dec 26, 2007 | 09:10 PM
regency's Avatar
i did my headers with that stuff and started cracking and flaking in the first day
Old Dec 26, 2007 | 09:36 PM
Stoichiometric's Avatar
That's a bummer to have a leak like that. The exhaust looks good now. I like to see the welds anyway, looks hand built instead of bent overseas.
Did you strip the factory paint before painting with the Duplicolor?
Old Dec 26, 2007 | 10:43 PM
BlackGMC's Avatar
Resident Retard
Keeping paint on headers is completely different than exhaust piping.... I like to see welds too, if they look like dimes layed on top of each other. Unfortunately my welds almost look like that but I am a bit out of practice... On my mustange years ago when I did the exhaust on it, I smoothed down every weld so the entire exhaust looked like one seamless pipe, even the mufflers, however that took days to do... The paint really does not matter it will be dirty in a few days anyways, mainly just personal satisfaction..
Old Dec 26, 2007 | 10:45 PM
budhayes3's Avatar
PT's Slowest Truck
Good catch man, leaks like that can be tough to find, especially when you don't know that an exhaust leak is what you're trying to track down. I've got a Magnaflow x-pipe in the "to be installed" section of our storage space...if I ever get around to re-doing my exhaust, I'll be sure to pay extra attention to the welds.
As you mentioned, it sucks when a company with a good rep exhibits sub-par quality, especially when you're looking for a problem with the truck and trusting that your name brand part isn't the cause
Old Dec 28, 2007 | 10:25 AM
regency's Avatar
yea i sandblasted them them sprayed the coating on and let dry for like 2 or 3 days while i was working on getting the motor in when i swapped to the ls1. i actually used a eastwood header coating 1200*. my g/f's dads race car he used the same can of stuff but painted on with a brush and hasnt had any problems so i dunno what happened
BKnBLK05
Dec 28, 2015 08:52 PM
ou812sm
14
Jul 27, 2015 04:38 AM
fillpot
Jul 26, 2015 07:21 PM
ou812sm
Jul 23, 2015 02:11 PM
GM-only
Jul 19, 2015 10:48 PM
