Guys i need seriouse help!!!
Old Dec 27, 2006 | 02:17 PM
ChEvY mAn 707's Avatar
Default Guys i need seriouse help!!!
k this is my deal, i want a supercharger but my truck its a 2000 5.3 and has 123,000 miles on it k, and i duno if the tranny and rear end that stuff will hold up, i need advise and info on what you guys think if it will or not. thanks
Old Dec 27, 2006 | 02:30 PM
CHEVRACER83's Avatar
My Advice....
The 5.3 Is A Great Motor.... But It Is Definitely Getting Old At 125,000. It May Hold Up For 20 Miles Or 20,000
The Trans If Its The Original.... Will Probably Be On Its Way Out Soon... If Its The 4l60e Which Im Sure It Is.... It Will Most Likely Blow Up Very Quickly When Dealing With Blown Power
The Diff Should Be Fine As Long As Its Been Well Maintained.
Old Dec 27, 2006 | 02:50 PM
thanks man n e more info?
Old Dec 27, 2006 | 02:51 PM
Well Tell Me What You Wanna Know
Old Dec 27, 2006 | 02:59 PM
lol i duno i guess you just told me what i was askin that it wont hold up for much longer so i duno if im goin to blow it thanks.
Old Dec 27, 2006 | 03:30 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
If I were you, which I'm not, I'd spend the money elsewhere. If you plan on keeping your truck...the $4500 or more could go to a new 6.0 for about $2000 or so, and a new level 5 trans for about $2-$2500. Then you would have a NEW motor and NEW trans. You could remove the TM at that point and with a few bolt on's run in the low 14's or better. With the blower you'd run about the same...unless you upped the boost...and then it would hurt the trans and possibly the motor. It would basically be a ticking time bomb. The new motor and new trans would put NEW life back into your truck. Thats my 2 cents.
Old Dec 27, 2006 | 04:01 PM
thanks alot man that really helps.
Old Dec 27, 2006 | 07:40 PM
chevyguy7802's Avatar
If i was you id do a compression test on your motor to see the condition that its in before i made any choices.
Old Dec 27, 2006 | 07:46 PM
SORRY MAN HOPE I DIDNT SEEM RUDE..... JUST TRYIN TO SAY THAT THE 4L60E LIKE MOST OF US HAVE FOUND OUT IS A VERY EXPENSIVE AND VERY WEAK PAPERWEIGHT...
I HAVE A 2006 1500 AND IM ALREADY MAKING PLANS FOR WHEN MINE GOES BOOM
Old Dec 27, 2006 | 07:51 PM
nightrunner's Avatar
Mr. Obvious
definitely need a new tranny and personally i wouldnt supercharge a motor with over 100k miles on it but its all up to you
id also suggest a aftermarket limited-slip for the rear
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
