gtech's pushing the 4.8, wow!
Old Dec 10, 2004 | 08:17 AM
  #21
zippy's Avatar
looks like the 4.8 is a bit soft off the line, but appears to crank well once under boost. impressive how quick that thing goes at around stock duramax boost levels. good thing you have it as a spare.
Old Dec 10, 2004 | 09:57 AM
  #22
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I am starting to think Jim's blender can do 11s
Old Dec 10, 2004 | 12:30 PM
  #23
8ALTNG's Avatar
Originally Posted by Yelo
you'll probably be the only person on the planet ever to achieve 600+hp out of a 4.8 liter V8
I wouldnt say that he is going to be the ONLY person to every see 600+hp out of a 4.8 liter v8
Old Dec 10, 2004 | 12:48 PM
  #24
hellbents10's Avatar
LS1Tech Sponsor
Its time for cal tracs and drag radials Jim. I have pulled a 1.51 60ft on 235/60's so I knwo you can go 1.4's or better as far as 60's go. Keep that 8.5" in there too, everything else is too damn heavy lol.
BTW my blender goes 9's.
Old Dec 10, 2004 | 01:37 PM
  #25
zippy's Avatar
he's almost trying to get you to change your sig.
Old Dec 10, 2004 | 02:34 PM
  #26
I AM A MOTHERF*CKER
Originally Posted by hellbents10
IBTW my blender goes 9's.
Only with juice
Old Dec 10, 2004 | 02:38 PM
  #27
8ALTNG's Avatar
Ya thats what I've been thinking. But that wont have to happen
Old Dec 10, 2004 | 02:56 PM
  #28
There was one F-body guy who had some trouble with his waiste gate i think and spiked something like 35psi boost. On the boost spike he also skiked the HP over 1100 to the wheels.
Spend an hour and slap in some stiff springs and stiffer WG spring, and push it up to 30psi at 6000rpms. That would make for some good dyno numbers.
Old Dec 10, 2004 | 04:11 PM
  #29
parish8's Avatar
single digit dreamer
changing valve springs and wg spring and then tuning for more boost is well over an hour, thats not the problem though. it is the cost of the dyno. i need to get hooked up with someone that has a dyno.
i kind of have a feeling if i went thru the work and then started at 18psi and worked up that we would run into a new limit of something real quick.
Old Dec 10, 2004 | 05:23 PM
  #30
foxspy's Avatar
How much do you pay per hour on the dyno?
