Got bored, tinkered with my ram-air!
Old Nov 25, 2003 | 08:19 PM
Default Got bored, tinkered with my ram-air!
After my trip the track and having my truck run quicker without the ram-air than with it, I'm still thinking about what some guys said. They said that my MPH was higher on the ram-air runs so it made more power but the times may have been slower because of a traction problem, not because the ram-air didn't work. I've gotten used to the quieter intake noise though and decided to play around and try to combined the ram-air with no extra openings in the airbox. The two air inlets get there air from what gets around the headlight and turn signal, which is a pretty small opening and my pea brain can't see how it is enough air. I took the lights out and part of the wheel well liner off, there is a channel that goes up between the outer fender and frame. I decided to try and route the ram-air duct up the channel to provide more air to the airbox. The 4" duct I was using for the ram-air was to big to use so I used some 3" duct I had, I positioned the end of the duct just below the lower airbox opening in the fender. To hold the duct in front of the fender opening I used a metal clip like a big paper clip. I put the scoop back where I had it and used the 4" duct to about 16 inches then I used a 4"/3" PVC reducer to connect the 4" duct to the 3" duct. I'm also hoping that reducing the duct size may increase air velocity but I'm not sure it will. I know it's not a "ram-air" system but it may provide more cool air into the lower air inlet. It may not even do anything but it was fun tinkering for a couple of hours.
Jim
Old Nov 26, 2003 | 07:36 AM
leochevy2001's Avatar
Some pics please.
pewter00
11
Oct 20, 2023 05:40 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
Wolftrk99
Oct 2, 2015 08:17 AM
01silvy
Sep 26, 2015 10:20 PM
dantheman1540
Sep 15, 2015 08:28 PM
