Good setup for DD?
Old Dec 4, 2006 | 12:15 AM
  #31
LS1TRUCKGUY's Avatar
Originally Posted by jons03
Your truck sounds good man! A 5.3 should sound pretty similar huh? What kind of exhaust are you running? The idle sounded pretty smooth. I bet I will regret it if I go with the 114. So why does that fluid go through the TB anyways? Is there any purpose to it? I'll look at those lines tomorrow. Thanks
the coolant in the tb is for faster warm ups and to keep the tb from freezing if you are up north in the cold weather.
Old Dec 4, 2006 | 12:16 AM
  #32
TouchOfEvil04's Avatar
I have the Dynatech longtubes with a borla duel side split catback.
On a 5.3 it should idle about the same since mine idles rough right now.I have a almost stock tune right now so with a nicely tuned 5.3 it will idle about like what you heard maybe even better.
The fluid goes through it help prevent the tb from freezing up.But unless you have temps that are 20 and lower fairly often you never need to have it hooked up.
Old Dec 4, 2006 | 12:31 AM
  #33
jons03's Avatar
Oh........That sucks because it's getting really cold here now. I've been scraping ice off of my windshield every morning. I should probably leave that alone until summer time. As far as the exhaust goes then....I should probably just run 3in. back from where the y-pipe ends? I can't wait to get this cam kit now!
Old Dec 4, 2006 | 08:48 AM
  #34
TarheelZ's Avatar
You may already be aware of this but you can buy the Dynatech headers without the y-pipe. You don't have to buy the entire SuperMaxx 'system', just the headers.
My exhaust consists of a SI/SO 3" Magnaflow, 3" single pipe with a Magnaflow 4" tip. If you'd like, I can email a sound clip to you. I didn't have the heads and cam work done when the clip was recorded but it still sounds pretty much the same.
Old Dec 4, 2006 | 10:31 AM
  #35
jons03's Avatar
Actually I didn't know I could just get the headers. Cool. Yeah, an exhaust clip would be great, because that is the exhaust I'm kind of leaning towards now. Thanks
Oobray
Jun 13, 2022 03:38 AM
mhorn0817
Jul 8, 2017 01:54 AM
JordanH
Aug 8, 2015 07:59 PM
Three6GMC
Aug 3, 2015 07:53 PM
00pooterSS
Jul 16, 2015 03:03 PM
