Good setup for DD?
Old Dec 3, 2006 | 04:42 PM
nightrunner's Avatar
Mr. Obvious
if you are a 1500 1/2 ton you have a 10 bolt rear axle
a high 14 should be possible with just the first 3 and id say a 14.2-13.8 with the rest (cam stall gears etc.)
Old Dec 3, 2006 | 04:44 PM
Mr. Obvious
yours would be either the 2nd or 4th not sure on the spline count probably 2nd
Old Dec 3, 2006 | 04:45 PM
Mr. Obvious
some people are runnin about 15.3 STOCK
Old Dec 3, 2006 | 04:54 PM
jons03's Avatar
Oh wow, didn't expect those times. 13's would be cool. It is a 1500, so for sure a 10 bolt? Do you know if the long tube pacesetter headers come in a smog legal one? Or any long tubes headers that are CA. legal? I've been trying to find some but there seems to not be that many that are. I saw the supermaxxs? and want those, but don't want to drop 1500 for headers/cats...lol
Old Dec 3, 2006 | 04:57 PM
jons03's Avatar
The posi unit is for the rear. I would'n't even need that at the track if I run 4HI huh? That would be mainly for traction while driving in 2wd?
Old Dec 3, 2006 | 05:00 PM
Mr. Obvious
i dont think there are any smoglegal lts for cali pm trever1t on that issue
im 95% sure on the 10bolt i dont think gm had a 12bolt in anything stock 10 bolt in 1500s, 14bolt 9.5"rear in ss and vhos and 14 bolt 10.5" rear in hds
pacesetters are definetely not smoglegal if you move the location of cats from stock its illegal in cali i think
in cali i think the jba headers are the best
Old Dec 3, 2006 | 05:06 PM
jons03's Avatar
Hmmm. That sucks. I was looking at the JBA's and these edelbrocks. Seems to be good quality and a very good price especially for being ceramic coated. http://store.summitracing.com/partde...5&autoview=sku Smog legal too
Old Dec 3, 2006 | 05:10 PM
jons03's Avatar
TR Cam(220/220 .551/.551 114) That cam seems perfect for what I want. I wasn't sure what the difference between 114 and 112 though? Both cams had the same specs except that part. Something about the lobe separation? Which one will sound the most "lopey"? 112?
Old Dec 3, 2006 | 05:13 PM
Mr. Obvious
im not too sharp about cams but i believe the 112 will lope harder, have the power lower in the power range, be harder to tune, have the power in a more narrow powerband
you might want to make a new thread to find out more about the cam
Old Dec 3, 2006 | 05:29 PM
jons03's Avatar
K, thanks, I'll look into it.
