Going to order my Eaton. Got a few questions
Old Dec 11, 2004 | 05:57 PM
  #21
slowprocess's Avatar
[QUOTE=TnTrk53]
Originally Posted by BADMOFO
I'd keep the 3.73. I think anymore gear would just make more traction problems, especially with the short lower profile tires that you run.
Me too.
How you doing, Jim?! Haven't heard from you in a while! You going to Hattiesburg tomorow?
Old Dec 11, 2004 | 06:53 PM
  #22
i have 3.73's in my truck but a peg leg. Would i need to change the gears if i got eaton and a Ta girdle.
Old Dec 12, 2004 | 01:12 AM
  #23
chris99gmc's Avatar
where are you guys finding the best prive on these units?
I'm looking for an Eaton E-locker or eaton posi.
Old Dec 15, 2004 | 09:04 PM
  #24
TTT Is this what I need, gentlemen? If so, it's about to be on the way.
Old Dec 15, 2004 | 11:21 PM
  #25
Damn, guys, forgot to post the link to what I was talking about. This is what I need right?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Dec 16, 2004 | 11:51 AM
  #26
goshawk23's Avatar
Truck addict
yea that is the one you need. i just checked the part number at summit and they match. what did you do when you had the gears put in. did you do a install kit or just use what was in there? i would call summit and ask what is needed for this.
remember get the GM additive and i think two bottles of gear oil. non synthetic if you can find it.
Old Dec 16, 2004 | 11:54 AM
  #27
goshawk23's Avatar
Truck addict
look under notes
if that don't work, just look at the summit racing website, search eaton traction and it will pull up what you are looking for
Old Dec 16, 2004 | 12:40 PM
  #28
vanillagorilla's Avatar
As far as the E-locker goes......I would stay away from it! The jury is still out on whether these things work or not. The fluid they use has electromagnetic properties, and it doesn't always behave as it should. If you want a locker, get a locker. If you want to control lock-up, then an air locker is by-far a better choice. Talk to the off-road guys, they'll tell you how it is.
03keverado, no you don't need to change your gears with switching to an Eaton/girdle.
I've done one rear-end, and after doing it I will gladly write a check to have it done by a professional. Like Flyer said, its just not my cup of tea. I'm sure a lot of you guys could do it on here. It's definatley a lot less complicated than building an engine. BUT, if something goes wrong you can't point the finger. My truck is my daily driver, and I don't have the time. If its not your DD, and you have the time, them go for it. You'll learn a
lot.
BTW labor costs on a posi w/no-gear swap is only about $200-$300. Cheap insurance if you ask me. And aftermarket gears don't whine if they're set-up properly!
Oh yeah, you might want to look into the Ford friction modifier. I run that in both vehicles and both rear-end shops here in town swear by it! Its a lot better than the GM ****, at least thats what I've been told. You can get it at your local Ford stealership.
Old Dec 16, 2004 | 03:37 PM
  #29
ThunderZ28's Avatar
12 Second Club
just to let you know Jeremy..
That is who I bought my eaton from...
got mine a bit cheaper tho..
327 shipped to my door.
real good service tho..
shipped real fast
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Stainless Works
13
Nov 5, 2015 03:31 PM
Lamartian92
Sep 10, 2015 09:27 PM
Lamartian92
Aug 21, 2015 01:43 PM
USMCvet0311
Aug 1, 2015 07:45 AM
