GM ASA Cam
Wanting to run a GM ASA Cam in my 6.0LQ9. Specs are 226/236 .525 .525 110 LSA. I'm worried about valve clearance issues. Anybody running this cam or one with similar specs? Did you have to machine deeper reliefs into the pistons?
Actually, the LQ9 I have is out of an 03 Escalade and is going into a 79 TransAm. I plan to run a t56 six speed and will probably have it tunned once the car gets running. What is involved in a tune and how much do they usually run?
Check this site for a tune you can search on here for nelson tune and find pages of info on them. Mostly they change fuel, timing, and shift points. Not sure how much lift the factory springs will handle but you can get the yellow ls1 springs I think that sdpc has them. They will allow for .550 lift I think. Maybe some one will chime in with a little more knowledge on these motors.
Nelson
Nelson
I thought you had to run sodium filled valves with that cam??? not sure, just something to check
Anyway, I'm off to the emissions testing site with my 01 Dodge Ram, its usually more fun than a barrel of monkeys.
Originally Posted by OnyxSilveradoSS
Similar to mine with a narrow LSA, I might look at something with a wider LSA, so your power band is wider...
Just understand that the ASA cam is still really mild. Personally, I'd go carbed and run something around 235-238 duration and 600+ lift for an old TA. Gotta have the rumpity sound for old school cars IMHO!
